Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2011, 04:07 AM   #41
Drew1Down
CF Senior Member
Drew1Down's Avatar
do not go dynaspark, there not dynaspark (from back in the day) anymore, just put a dynaspark in my 93 vette and it looks nothing like the one i put in my lt1 monte carlo a few years ago. I think they are using chinese optical pickups and not the japanese ones that lasted 100k miles like delco uses.
If i had to do it again id go MSD or mod an ACDelco OEM unit
Drew1Down is offline   Reply With Quote
Old 07-16-2011, 04:39 AM   #42
Charleston2012
CF Senior Member
It would be nice if you could buy just the Japanese Mitsubishi Optical sensors.
Charleston2012 is offline   Reply With Quote
Old 07-16-2011, 04:51 AM   #43
Drew1Down
CF Senior Member
Drew1Down's Avatar
Quote:
you sir, would be a hero if you can find the mitsu optical pickup GM uses, and buy a boat load becasue your going to sell alot of them.
that little optical pickup's origins of where its made have plegued opti users for years, no one can find where you can buy JUST the sensor. I have searched high and low and can't find it for the life of me!
Old 07-16-2011, 11:07 AM   #44
Charleston2012
CF Senior Member
Dodge used them years ago in there little V6 cars in the distributor. I think it was a Daytona. I got tired of researching.
I did find the opti bearing. The NTN bearing was only allowed to be bought by GM. But, there was a bearing that had a lip on it that could have been cut off and would end up being the same bearing.
Opti, not my favorite.
Old 07-16-2011, 11:46 AM   #45
mfi
CF Senior Member
mfi's Avatar
This one from Corvette Central is supposed to be a modded Delphi..guess I'll know when I get it. Going to loctite the rotor..and pray for the best..if it craps out on me down the road..well that may be it for her ..cause I don't have time to do major surgery all the time..might go back to a 72 GTO..real easy to work on...
mfi is offline   Reply With Quote
Old 07-17-2011, 05:00 PM   #46
vetteblack
CF Senior Member
vetteblack's Avatar
The factory delco did not give me good service, so the 1st time was the Accel. Not a good choice. 2nd opti was a summit. Not a good
choice. 2nd opti was a summit. Not a good choice, though better than the Accel. Thursday I put in a Cardone from Rockauto. It has a one year/18,000 mile warranty. And its $70 less the the 2 previous units and has a better warranty.
vetteblack is offline   Reply With Quote
Old 07-17-2011, 05:31 PM   #47
Charleston2012
CF Senior Member
I honestly believe anyone, except a genuine GM from the dealership is a rebuilt Opti with Cap and Rotor.
You cant buy the bearing, unless you are GM
You cant by the Optical Sensor, unless you are GM (OEM Mitsubishi ones, not China crap Sensors)
You cant get new aluminum housing, Unless you are GM or are willing to make your own like MSD.
But you can buy, in bulk, cap and rotors.
Rebuilts are Summits/Accels/Cardone/etc etc. Junk.
If you are a waxer who drives to and from work or car shows, they are fine. Anyone who drives it to enjoy with spirited driving, auto cross, HPDEs, then you are dancing with the Devil unless you buy Genuine GM, as they are more than likely new old stock thats just waiting for the stock to run out.
Old 07-17-2011, 05:44 PM   #48
vetteblack
CF Senior Member
vetteblack's Avatar
Cardone has a new and rebuilt. The one I bought is advertised as new.
Old 07-17-2011, 05:50 PM   #49
Charleston2012
CF Senior Member
Quote:
Take it apart and see what the Optical sensor and cap and rotor are made by. Yes, they may be new (but not the Mitsubishi sensor, for example), but I seriously doubt they have new housing.
Cardone is an average company. I have used their New water pumps too. One of them leaked. It was a warped housing.
Regardless, Good luck.
Old 07-17-2011, 05:56 PM   #50
vetteblack
CF Senior Member
vetteblack's Avatar
The delco lasted just 43,000 miles. Now granted, thats a lot more than the replacements I've been using, but it still doesnt give me alot of confidence. I think GM should have did a distributorless ignition, and we LT1 owners would be a lot better off.
Old 07-17-2011, 05:58 PM   #51
Charleston2012
CF Senior Member
The cardone says new, but without module. Wonder what that module is?
No one else advertises their Opti "without module"
Old 07-17-2011, 06:13 PM   #52
vetteblack
CF Senior Member
vetteblack's Avatar
I dont know, but its in and running. Just 100 miles on it so far.
Old 07-18-2011, 04:06 PM   #53
mfi
CF Senior Member
mfi's Avatar
Wonder if the Deltech or that other coil pack conversion is worth it...prolly can't hurt to get the high voltage out of there...
Old 07-18-2011, 07:10 PM   #54
BucfanTitan
CF Senior Member
BucfanTitan's Avatar
Since a lot of people are replacing the optispark who has the best write up on the Internet to replace one. If my mechanical skills are pretty basic is this a task I can take on. Also having a 95 any different then the 92 mostly talked about in this thread?
BucfanTitan is offline   Reply With Quote
Old 07-18-2011, 08:34 PM   #55
mfi
CF Senior Member
mfi's Avatar
The hard part is getting off the balancer but also basic shop practices such as cleaning gasket surfaces, removing and replacing seals..this stuff is hard to learn off the web..not that you can't but if you get it wrong..its a mess and you could wreck the opti..again...but if you want to try it..we can walk you through it..it is a mother of a job..and I've been doing this stuff for 30 years..just let us know..what I can't..or it seems no one can..is what is the best opti to buy..
Old 07-19-2011, 12:49 PM   #56
JM95
CF Senior Member
JM95's Avatar
Modify for vented Optispark and install Chandler Motor Sports Vented Optispark with lifetime warranty for $135. This has been a better solution on my 95 then any other expensive products $300 or more.
JM95 is offline   Reply With Quote
Old 07-19-2011, 01:28 PM   #57
mfi
CF Senior Member
mfi's Avatar
The one I'm getting from Corvette central is modded with vents..469.00 though..they claim its a modded Delphi..we'll see when I take it apart to locktite the rotor..
Old 07-19-2011, 01:52 PM   #58
93VettePilot
CF Senior Member
93VettePilot's Avatar
Quote:
This has been my experience too with 2 different LT1 cars. Get the vented version and make sure the plug wires are high quality. It will last for 200,000 miles.
93VettePilot is offline   Reply With Quote
Old 07-19-2011, 05:19 PM   #59
mfi
CF Senior Member
mfi's Avatar
Quote:
Bought the stock oem wires..they lasted 100,00..figure I don't need bigger ones as the motor is stock and prolly will always be...
Old 07-19-2011, 07:11 PM   #60
BucfanTitan
CF Senior Member
Well a vented opti seems like a good way to go. I think I am able to figure out the importance of removing old gaskets and puting new ones on correctly. If I can change a gasket on a lower unit outboard and rebuild a small outboard carb. I should be able to figure this out.
So yes mfi I would like to try this task. If you have a good write up I would like to read it.
Thank you for your help.
Reload this Page Final word on best opti spark to buy
Tags
1992, buy, chandler, cms, corvette, delco, loctite, lti, motorsports, msd, opti, optispark, prices, spark, warranty
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking to buy a 2 step Smith3535 C6 Corvette ZR1 8 07-24-2014 01:22 PM
Top Gear Speed Week 2014 Issue Released! saadooness C7 General Discussion 6 07-14-2014 11:48 AM
In just one word, what does OT think of.... dbraver2 Off Topic 58 04-24-2014 10:50 AM
Rubio's response NoOne Politics, Religion & Controversy 119 02-15-2013 01:33 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
