Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2002, 02:11 PM   #1
ZZZASY
CF Senior Member
ZZZASY's Avatar
Default If ignition switch is bad, can you push start a car?
Hi all, I posted a couple of days ago about my car not turning over or doing anything. The response I got back was its either the ignition switch, starter, or theft deterrent. My question is, if it was the ignition switch, I wouldn't be able to turn the ignition on and push start the car would I. If it was the switch, wouldn't it not get current to run?
TIA
Curtis
96 LT4
ZZZASY is offline   Reply With Quote
Old 04-25-2002, 02:19 PM   #2
a851yy07
CF Senior Member
a851yy07's Avatar
Default Re: If ignition switch is bad, can you push start a car? (ZZZASY)
If it is a manual transmission and when you turn the key to the on position everything that is supposed to come on comes on then theoreticly you should be able to push start the car. I hope you have a lot of help and a steep hill as well.
a851yy07 is offline   Reply With Quote
Old 04-25-2002, 02:22 PM   #3
scorp508
CF Senior Member
scorp508's Avatar
Yes and no. You can, but the neutral safety switch on your clutch pedal is going to stop you from doing it.
scorp508 is offline   Reply With Quote
Old 04-25-2002, 02:25 PM   #4
91mongoose
CF Senior Member
Send a message via Yahoo to 91mongoose
Default Re: If ignition switch is bad, can you push start a car? (a851yy07)
Push starting is not hard to do. I've done it with my wife driving plenty of times. If your dash lights up when you turn the ignition to on push starting may work. If VATS (anti-theft) is the problem, I think you're still out of luck because that kills the ignition as well as the starter (I think, wouldn't be much of an anti theft if all they had to do was push start it :D)
The key to push starting is to use 2nd gear, 1st gear tries to turn the motor over too fast causing the car to slow to a stop almost immediately. Make sure you are wearing tennis shoes or the like, push starting with leather soles doesn't work well :). You have to have an manual tranny, an automatic won't push start, but since you have an LT4 you have a stick so you're good to go.
[Modified by 91mongoose, 1:05 PM 4/25/2002]
91mongoose is offline   Reply With Quote
Old 04-25-2002, 02:26 PM   #5
91mongoose
CF Senior Member
Default Re: (scorp508)
The safety switch only interrupts the starter circuit, not the ignition, so it won't have any effect. Been there, done that :)
Old 04-25-2002, 02:32 PM   #6
ZylaRace
CF Senior Member
ZylaRace's Avatar
Default Re: (91mongoose)
Scorp,.. What were you thinking? :rolleyes: :nono:
ZylaRace is offline   Reply With Quote
Old 04-25-2002, 02:37 PM   #7
scorp508
CF Senior Member
scorp508's Avatar
DOH!!! :D It's the little things that get ya. :jester
Old 04-25-2002, 04:00 PM   #8
ZZZASY
CF Senior Member
ZZZASY's Avatar
Hey guys got your responses, but you are missing the point. I have already push started so I know that works. My question is could I push start it with a bad switch. I'm trying to rule out some of my problem options. I disconnected the battery last night to let it sit for 12 hours to see if its the theft deterrent system. My thought is, if I let it sit with no juice for that long, everything should reset, including the theft deterrent. I will reconnect the battery when I get home today. If it still doesn't do anything (I mean no whining at the starter); I think that pretty much rules out the theft deterrent which will leave me with the switch and starter. If I cannot push start with a bad switch, then that would rule out the switch and I can look into investing in a new starter. Just trying to eliminate items from the three potential problem areas I've been given.
TIA
Curtis
96 LT4
Old 04-25-2002, 05:06 PM   #9
Black87c4
CF Senior Member
Black87c4's Avatar
I'm thinking bad starter solenoid.
Black87c4 is offline   Reply With Quote
Old 04-25-2002, 08:24 PM   #10
91mongoose
CF Senior Member
If you can get to the starter solenoid, with the car in neutral and the parking brake set (VERY IMPORTANT!!!) you can short across the two terminals with a screw driver and see if the starter kicks over. If it does, switch, if not, starter.
Perhaps easier and certainly less dangerous is to remove the starter from the car and take it to your local auto parts store and have them test it. Push starting does not vindicate the switch since the start pole is never used and may be the part thats bad.
Old 04-26-2002, 12:58 AM   #11
Steve85
CF Senior Member
Cruise-In V Veteran
Steve85's Avatar
Yes and No, if the switch contacts at the start position we're bad and the contacts in the run position were good, you would be able to push start a car with a bad ignition switch. However if the switch contacts in the run position were bad, you would not be able to push start, your fuel pump wouldn't run nor would your ignition system fire.
I can tell you that starters crap out far more frequently than ignition switches.
Try the loud wrench on the starter test. With a helper turning the key to start, tap the starter solenoid with a hammer. If the solenoid releases and the starter turns over, go buy a starter
Steve85 is offline   Reply With Quote
Old 04-26-2002, 10:34 AM   #12
91mongoose
CF Senior Member
Default Re: If ignition switch is bad, can you push start a car? (91mongoose)
What about that clutch saftey switch? That would cause the same problems, and it wasn't menitioned as a possible candidate. You can bypass it with a jumper wire and see if it cranks then.
Reload this Page If ignition switch is bad, can you push start a car?
Tags
bad, c6, car, corvette, deterrent, ignition, neutral, push, roll, safety, screwdriver, start, starter, switch, theft
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
