Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2011, 05:08 PM   #1
ironvapor
CF Member
Default vettaid dash kit?
Could those members who installed Vettaids gauge kit on their C-4s give an update on how the units are working out? The digital dash on my 89 finally gave out and I am trying to decide whether to repair it or replace it. Thanks in advance
ironvapor is offline   Reply With Quote
Old 07-10-2011, 10:08 AM   #2
856SPEED
CF Senior Member
856SPEED's Avatar
fine piece....have one installed in my 85....much better (for me and my car's build style)......however I have a couple of issues:
speedo jumps around at low speeds; over 40 OK....they sent me a new speedo.....same thing......they are telling me it may have something to do with my speedo gear or speed sensor......it could be on my end....don't know for sure yet.......
light doesn't work on my water temp. gauge (dash light)......don't know what happened there?? they sent me a new one though......have not installed it yet.....just can't see it in night driving right now....
the high beam indicator light in the middle of the dash is very, very, very, bright blue, blinding the driver.......they sent me a dimmer switch or something to install to bring down the brightness level......have not done that yet either.....
the fit and finish is nice......I like the white face Auto Meters (that's the option I went to), so that alone is great and the tach is a HUGE improvement over stock....don't need a 10,000 RPM limit tach, but hey, it works great and looks great!!
__________________
85 Vette with many modifications: ZF6, TPIS/AFR alum. heads, TPIS LT's, TPIS ZZ9 roller cam, TPIS 52 mm throttle body, RT hi-flow cat., miniram, 355 ci. rebuilt engine, 3.73 gears; air pump delete, "1990 ZR1style" rear fascia w/admiral blue GS stripe, custom wheels
856SPEED is offline   Reply With Quote
Old 07-10-2011, 10:12 AM   #3
Jims1988C4
CF Senior Member
Jims1988C4's Avatar
Send a message via AIM to Jims1988C4 Send a message via Yahoo to Jims1988C4
Can you post a pic ???
Jims1988C4 is offline   Reply With Quote
Old 07-10-2011, 04:03 PM   #4
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
Quote:
__________________
`87 yellow coupe (for fun)
`90 supercharged coupe (for more fun)
"EVERY DAY ABOVE GROUND IS A GOOD ONE"
The only thing that stops me from being rich is the lack of money.
Dogs are not our whole life, but they make our lives whole
kenv is offline   Reply With Quote
Old 07-10-2011, 07:11 PM   #5
Calderone
CF Senior Member
Calderone's Avatar
pics!
Calderone is offline   Reply With Quote
Old 07-10-2011, 07:54 PM   #6
ironvapor
CF Member
pictures and information are available at www.vettaid.com if no one posts them here.
Old 07-10-2011, 08:10 PM   #7
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
I love it. Had to change out 2 sensors. It was basically plug 'n play.
This is in my '89.
The only thing I don't like is the blue high beam indicator. At night it's entirely too bright. And since you're eyes don't dialate to blue light (hence police cars having blue lights) it makes it very annoying. I ended up covering it with electrical tape.
Picture 2 was taken before I switched out the oil pressure and temp sensors. It's a 6 speed too, so the trans temp isn't being used.
Black89Z51 is offline   Reply With Quote
Old 07-10-2011, 09:34 PM   #8
oldalaskaman
CF Senior Member
oldalaskaman's Avatar
Quote:
This is in my '89.
is that the final fit around your steering column?
oldalaskaman is offline   Reply With Quote
Old 07-11-2011, 04:49 AM   #9
Ray Quayle
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Ray Quayle's Avatar
What do you do for odometer readings when registering these things?
__________________
Ray Quayle
'86 Indy PaceCar, 4+3 (6895 of 7315)
Lcdr Operations Officer USS Corvetteforum SSB Y2K Gold
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
Black Sheep Squadron Member
Ray's Corvette
ray_quayle@btopenworld.com
Ray Quayle is offline   Reply With Quote
Old 07-11-2011, 07:11 AM   #10
856SPEED
CF Senior Member
856SPEED's Avatar
Click the image to open in full size.
[My steering column looks nothing like the one above! I would have taken it back......
I have posted these pics many times in the past......thought most have seen it.....it's also on my album pics if you want to see other mods.....
__________________
Old 07-11-2011, 07:13 AM   #11
856SPEED
CF Senior Member
856SPEED's Avatar
another angle...........took the "Vett Aid" logo off mine though......don't want that anymore than space around the steering column........hopefully someone took care of that above......
__________________
Old 07-11-2011, 07:22 AM   #12
856SPEED
CF Senior Member
856SPEED's Avatar
Here's my car.......(now I need to change the interior to white seats/blue inserts and dark carpet......next project......the interior needs to be addressed.....original stuff in it........(other than the six speed shifter/dash cluster of course)
__________________
Old 07-11-2011, 07:58 AM   #13
dclafleur
CF Senior Member
dclafleur's Avatar
Send a message via AIM to dclafleur
Has anyone used the Dakota digital replacement dash?
dclafleur is offline   Reply With Quote
Old 07-11-2011, 03:07 PM   #14
Black89Z51
Quote:
Yes. I was a bit disappointed that a piece that cost that much wasn't centered, but about a 1/4"--3/8" offset to the left. Everything else was ok. The vent is a pain in the *** to get in there. I think I had to bend something, but it's been so long since I've installed it.
Old 07-11-2011, 03:09 PM   #15
Black89Z51
Quote:
I'm not sure there is a way to put the actual miles on the new odometer. I think you would have to call autometer to see if that would be possible.
Old 07-11-2011, 04:15 PM   #16
Ray Quayle
CF Senior Member
Cruise-In I Veteran
Ray Quayle's Avatar
Oh, so the Autometer speedo has a built in odo? It's not just a trip odo? Very cool! Even better if you can set it to actual miles.
Old 07-11-2011, 04:46 PM   #17
Black84
CF Senior Member
Black84's Avatar
I've had mine in for about 800 miles now and am very satisfied with it. My only issue is the bright light indicator... the blue LED provided in the kit is extremely bright. I put a drop of black paint on the top half of the indicator and that helps.
Black84 is offline   Reply With Quote
Old 08-22-2011, 09:11 PM   #18
cttech455
CF Senior Member
cttech455's Avatar
Its primarily a track car so I never installed the vent
cttech455 is offline   Reply With Quote
Reload this Page vettaid dash kit?
Tags
aluminum, c4, corvette, custom, dash, dashboard, film, gauges, installation, kit, kits, panel, vettaid, vetteaid, vetteaide
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
