Pke
Pke
I have a 1996 and was wondering do all C4's have them? Would there be a code on the VIN. I searched and the people with PKE's had a PKE fob but all I have is the ignition key with chip. I'm going to add an aftermarket alarm and want to know if my car has PKE. Thanks in advance, Ed
Your car did have the PKE (Passive Keyless Entry) system when it left the factory.
This was standard on all '93-'96 Corvettes.
What functions does it have and is it worth it to buy the fob and how much is it. Also, I've heard that you have to dis-connect it to put in a aftermarket alarm. What does the tech have to do?
I like the PKE and would never recommend an aftermarket. However a few quick checks to help you make a decision.
Before you go out and buy a FOB for $75-$150, check this one item. In the lower left hand area of your DIP light panel there is a PKE light. When you turn you key to ON, the light should light for 2 seconds. If it does light the PKE receiver in the car is probably working.
Going to the next step if the PKE light comes on is trying the programming mode. I know if you don’t have a key FOB but you can go about half way right up to the point where the receiver identifies and programs in the FOB. If you get that far there is a good chance the receiver is good and might be worth while getting (or trying) a FOB.
On the other hand if the PKE light does not light on the DIP when the key is turned to ON, then the PKE receiver in the car is usually bad. Although this is a quick assumption, it usually turns out to be correct.
If the receiver is bad, costs about $100-$200 for a (used) receiver and the dash pad needs to be removed which is a pretty good 2 day job for most people.
I would find out what my car status is and then you can make a better decision in what direction you want to go.
The factory system locks and unlocks the doors when you approach and walk away from the car. This also engages the factory alarm. It is not a typical system, you cannot press buttons to lock and unlock the doors. Read the owners manual to understand how it works. A replacement fob will cost you about $130. Before you buy one go through the programming sequence in the owners manual and make sure everything works up until you need the fob. If it does, you may want to buy a new fob. If it doesn't, it will cost a lot to replace the interior parts to make the factory system function like new. Some people really dislike the way the factory system works, I thinks it is fine.
If your factory PKE is working as intended don't switch. It is a great system but you must read the owners manual to learn all of it's features. I wish all of my cars had it.
