1991 cold start problem
Old 06-29-2011, 09:46 AM
  #41
hln111
hln111's Avatar
No dtc codes. I've shot directly into tb and also have shot into air cleaner. Both work equally as well.
hln111
Old 06-29-2011, 10:02 AM
  #42
joe paco
joe paco's Avatar
hln111
unplugged TPS before cranking? a lot simpler advice than changing injectors! lol.
the tech bulletin that was mentioned had that as one of the steps in "L98: cranking, no start." a caution here, not to overlook that most of the data collection, test lights on, off, etc, has to be done with engine cranking.
also, the question was,not one cyl tries to fire? would indicate spark and some air/fuel mix.
it is in an old post here, will see if I can locate it and send to you.
joe
Old 06-29-2011, 10:07 AM
  #43
hln111
hln111's Avatar
Great thank you. Not one cyl. try's to fire until starter fluid, then fires right up.
hln111
Old 06-29-2011, 08:41 PM
  #44
joe paco
joe paco's Avatar
hln111
hin11 in case you missed it, the info was in the post right under this one, last modified by me, can't recall the original poster. sent at 10:07 or so.
Quick Reply: 1991 cold start problem
