Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2011, 12:07 PM   #1
Ralphbf
CF Senior Member
Ralphbf's Avatar
Default Starter Relay
Okay I checked the threads here, I purchased an almost useless Haynes shop manual.
New starter
I can hear the fuel pump working
Engine won't crank
Where is the starter relay?
Ralpj
Ralphbf is offline   Reply With Quote
Old 06-22-2011, 12:46 PM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
Might help knowing what year ?
AGENT 86 is offline   Reply With Quote
Old 06-22-2011, 02:14 PM   #3
jfb
CF Senior Member
Can you hear the starter solenoid click? The only relay in the starter circuit is the VATS enable relay whick allows 12v from the crank contact on the ign sw to get to the starter solenoid.
jfb is online now   Reply With Quote
Old 06-22-2011, 04:14 PM   #4
Ralphbf
CF Senior Member
Ralphbf's Avatar
It's a 1990
Turn the key on and you can hear the fuel pump.
The starter seems dead. No nothing from it.
I can jump the starter and it cranks.
I understand there is a relay just for the starter and that is what I can't find.
Thanks again
Ralph
Old 06-22-2011, 04:25 PM   #5
hooked073
CF Senior Member
Send a message via AIM to hooked073
are you thinking of the solenoid? take a test light see it you have 12 volts on the s term of the solenoid while key is turned to crank. If you have 12 volts it is solenoid if not have to look futher.
hooked073 is online now   Reply With Quote
Old 06-22-2011, 05:23 PM   #6
Ralphbf
CF Senior Member
Ralphbf's Avatar
......I can jump the starter and it cranks.
Meaning it turns the engine over just fine.
My manual says there is a " Starter Interrupt Relay"
And that is what I'm looking for.
Ralph
Old 06-22-2011, 06:28 PM   #7
Hooked on Vettes
CF Senior Member
You never stated what transmission you have.
The schematic shows the starter current path for a manual transmission.
If you have an auto the current path goes thru the
Park/neutral switch instead of the clutch safety switch.
Click the image to open in full size.
Hooked on Vettes is offline   Reply With Quote
Old 06-22-2011, 06:40 PM   #8
Ralphbf
CF Senior Member
Ralphbf's Avatar
That one did slip by.
I have the 6 speed.
I'm simply looking for the physical location of the
Clutch start switch aka " Starter Interrupt Relay"
I know the clutch switch is working because the fuel pump works.
Ralph
Old 06-22-2011, 06:49 PM   #9
hooked073
CF Senior Member
Ralph
Sorry misread
Old 06-22-2011, 07:00 PM   #10
C409
CF Senior Member
C409's Avatar
...... Sounds like a VATS issue ... starter enable relay is activated by the ECM after receiving clearance from the VATS module which , in turn , needs to "see" the proper resistance pellet on the ignition key in order to allow the car to start ... BTW : Vehicle Anti Theft System .......
C409 is offline   Reply With Quote
Old 06-22-2011, 08:04 PM   #11
Hooked on Vettes
CF Senior Member
The starter enable relay is shown in the picture above.
It's a relay under the driver side of the dash cluster. The CCM
grounds the primary of the relay coil to energize the relay.
The clutch safety switch has nothing to do with the fuel pump.
When you turn the ignition key to start, 12 volts from the ignition
switch goes to the starter enable relay. If the key pellet resistance value
matches what the CCM was programmed for, the CCM will ground
the primary coil of the starter enable relay. The relay closes and
12 volts passes thru it to the Clutch Safety switch. If the Clutch pedal
is depressed, the 12 volts passes thru the switch to the Starter Solenoid
which is a Purple wire.
A defective Clutch Safety switch is a common problem. The contacts
inside the switch can't handle the current. The part is no longer available.
Some people bypass it.
When you turn the ignition key to On, does the Security light go Out or does it stay On?
If it stays on, the key pellet resistance is not being read properly by the CCM so the
starter will not engage.
You need to gain access to the starter enable relay. By taking some voltage
measurements at the starter enable relay socket it will lead you to what the problem is.
Remove the panel that contains the foot well lamp. You might also have to remove the
carpet that covers a metal panel that is bolted under the steering column. This will give
you access to the relay which is located under the front edge of the dash cluster.
Old 06-22-2011, 08:47 PM   #12
Ralphbf
CF Senior Member
Ralphbf's Avatar
I don't believe it's the VAT system because the way I understand it it disables the fuel pump also.
Fuel pump is a working.
So My hopes lay it the
But I could not find it any where, now I know where to look.
Thanks and I will keep the group updated.
Ralph
Old 06-22-2011, 08:55 PM   #13
Hooked on Vettes
CF Senior Member
If the key pellet resistance value does not match what the CCM
was programmed for, the starter will be disabled and the
computer will not pulse the injectors. The fuel pump will
still operate.
There is a starter enable relay and a clutch safety switch.
They are two individual parts.
Old 06-22-2011, 11:17 PM   #14
Ralphbf
CF Senior Member
Ralphbf's Avatar
The easy fix would be the Clutch start switch aka " Starter Interrupt Relay" ?
Old 06-23-2011, 12:11 AM   #15
jfb
CF Senior Member
Ralph
The VATS system measures the resistance of the pellet in your ignition key and if it is within 4% of the assigned value, it closes the start enable relay allowing 12v to continue from your ign sw crank contact on to the clutch safety switch and then to the starter solenoid. The VATS circuit will also allow the CCM to pulse the injectors so the engine can start and run. VATS does nothing to the fuel pump!
The start enable relay is behind the, "breadbox" on the right side of the dash. Most VATS problems are due to a defective clutch safety switch (jump yours and try a crank) or the contacts in the ign lock fail to make connection to the key pellet. I have replaced the ign lock three times on my 87 vette which have new contacts and I have permanently bypassed my defective clutch safety switch, but even with 240k miles and driven every day, my start enable relay is original. If I were you, I'd forget about the relay and concentrate on the clutch safety switch and also measure the resistance with the key in the lock on the two wires from above the steering column that go to a 2 pin connector. Unplug the 2 wires and measure the resistance across them with the key inserted. It should measure the same as the pellet.
Old 07-02-2011, 02:22 AM   #16
Ralphbf
CF Senior Member
Ralphbf's Avatar
It was the starter interupt relay.
What a PAIN.
Thanks to all.
Ralph
Reload this Page Starter Relay
Tags
1994, 2003, c3, c5, clutch, corvette, fuse, ignition, jump, located, relay, safe, safety, solenoid, start, starter, switch, wher
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
