Those who run 4.10s (Dana 44)
I am definitely watching this thread! This is my next upgrade after the 6 speed conversion. Where did you get the 4.10's? I did Richmond 4.10's in my LT1 firebird, when I did I had to upgrade the driveshaft. Do you have to upgrade anything else when you do the gears? Second, the Richmond gears were REALLY noisy(I will never buy Richmond gears again), you said they were quieter then stock 3.45's. So I would assume OEM gear sets are the way to go?
I didnt check I tossed mine out for 3.73s I used Richmond and paid for someone with gear experience to set it up and it doesnt whine at all. Are you guys all running drag radials or slicks? 4.10s ugh I hate them and never Recommed them
Oh yeah almost forgot. The reason I am going with them is I am converting my 4+3 into a 6 speed. I want the 6th gear to be usefull.
Why do you hate 4.10's? I had them in an auto Lt1 94 Trans Am and Loved them. They were just really noisy. Have you ever had Richmond 4.10's before. The reason I ask is I know 4 other people personally who had the same gears and they all complained about the noisy gears. Maybe its only the 4.10's, I have never had 3.73's so I can't comment on them. Not doubting your experience, just curious.
If you're building a 355 or smaller and are spinning 7k + or just want the best 60 ft time at the track and a shorter e.t go for 4.10s. Imo all they do is help break parts and require stickier tires making it a pathetic striaghtline car in the process.
No other upgrades are needed for the gear swap.
Got mine from the local Dodge dealer.
It looks like the OEM type are the most popular. Without starting another thread-What half-shafts are most of you using-Stock or Steel?
Thanks Again!!
Steve
Thanks Again!!
Steve
