Fuel and ran relays..
Old 06-04-2011, 01:25 AM
DA1984VETTE
DA1984VETTE's Avatar
Default Fuel and ran relays..
I have searched for this and didn't find what I was looking for. Could someone tell me where the fuel and fan relays are? I think the fan relay is the one by the wiper motor. I can't find where the fuel pump relay is. I have a FSM but couldn't find it under the fuel section. I just got it so I am trying to familiarize myself with it. The car is an 84, any help with pics would be helpful...thanks..
Old 06-04-2011, 06:23 AM
HlhnEast
HlhnEast's Avatar
Need to look in the electrical section of the FSM.
Old 06-04-2011, 08:53 AM
TWISTERUP
TWISTERUP's Avatar
pm sent
Old 06-04-2011, 10:31 AM
DA1984VETTE
Originally Posted by TWISTERUP
pm sent
I tried to look at what you sent. It is asking for a log on name and password on both...
Old 06-04-2011, 12:48 PM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
On the 86-88 MY the fan relay in on the driver's side wheel well housing just a little in front of the battery area. I'm not sure if this holds true for the 84 Vettes.
http://www.parts123.com/parts123/yb....5Z5Z50000050F#
Old 06-04-2011, 01:24 PM
TWISTERUP
TWISTERUP's Avatar
According to what i'm looking at that is correct for the fan relay on '84--also shows a auxilary fan relay directly to the left of the cruise control servo. I'm not sure what years or if all years used a auxilary fan.
Fuel pump relay is to the right of the brake booster. You should see the booster, to the right of booster the MAP sensor and to the right of the MAP on a bracket the fuel pump relay. hope this helps
Old 06-04-2011, 01:27 PM
DA1984VETTE
Yep you guys are correct...thanks for the help. My fan is now working..
To Fuel and ran relays..
Quick Reply: Fuel and ran relays..
