Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2011, 08:21 PM   #1
matt_jahn
CF Senior Member
matt_jahn's Avatar
Default Crank Bolt
what size is the center bolt in the crank pulley. i feel like i cant find a socket that even comes close to fitting. and its starting to frustrate me
Oh sorry, 92 lt1
matt_jahn is offline   Reply With Quote
Old 06-01-2011, 08:32 PM   #2
John A. Marker
CF Senior Member
John A. Marker's Avatar
I don't know if this will help but my 1985 uses a 5/8" standard for the crank bolt. See it a 5/8 will fit snug.
__________________
1995 LT1 6 speed - stock.
SOLD to son ** 1985 Coup -ZZ4 balanced, LPE 74211 , AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N , power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
John A. Marker is offline   Reply With Quote
Old 06-01-2011, 08:59 PM   #3
matt_jahn
CF Senior Member
matt_jahn's Avatar
yeah it was 5/8 thanks. do you have any other pointers for removing the hub, there isnt much room so im assuming there is some tricks
Old 06-02-2011, 05:55 AM   #4
oldalaskaman
CF Senior Member
oldalaskaman's Avatar
I ws thinkin those might be metric
oldalaskaman is offline   Reply With Quote
Old 06-02-2011, 07:33 AM   #5
My1st
CF Senior Member
My1st's Avatar
You can get a three bolt puller in there. I had to cut 1” off the center bolt of my puller. Only have about 4 ”- 5” to work in on my 89 coupe.
My1st is offline   Reply With Quote
Old 06-02-2011, 09:25 AM   #6
JackDidley
CF Senior Member
JackDidley's Avatar
In case you dont know, the LT1 pulley is not like the old SBC balancer. Its 2 parts bolted together. It does not pull off quite the same either.
JackDidley is offline   Reply With Quote
Old 06-02-2011, 09:28 AM   #7
jaa1992
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
Why do you want to pull the hub????
Or are you just trying to get the balancer off for an opti change?
For an opti change you just have to remove the 3 bolts holding the balancer on the hub and get the balancer off the hub.
jaa1992 is offline   Reply With Quote
Reload this Page Crank Bolt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
