785rwhp and 1137rwnm @ 16.5psi with "stock" heads.
Hello.
After some years of n2o I decided to make a turbokit this spring.
The engine setup: Stroker 383 with JE turbo pistons 9.6:1
Pump gas, ported stock heads with 2.02-1.57, stock intake, 58mm TB 160lbs injectors, VEMS, msd ignition. 3" ic.
BWs400 75mm 1.32. 60mm wastegate. 4" downpipe all way to rear, and splits to "stockstyle" 3".
Mild hydralic roller (int 504 ext 507) lob 112.
Going to the track on saturday.
Bill: What?
I live in sweden so it´s a local track.
And yes the car has stock IRS Exept polarytan and koni shocks. Stock blacktag with a hurst shifter and a mcleod street twin clutch with steel flywheel.
Well, don´t know what more info you want to know. It´s a street legal car.
Got full traction on fifth gear..
http://www.youtube.com/watch?v=Ofqy5gOtT_E
The car is almost soundless don't sounds like a 10 sec streetcar.
On the last test my blacktag trans went broke
With no response (0.0boost in first gear) the car went 10.81-136mph 60ft 1.66. 6.8x-105mph on 1/8. 30-40meters before finish the car was on rpm fuel cut of..
Raised rpm and boost.. But then I came on the boost fuel cutoff @ 1.5bar. And à broke transmission.
