Hard brake pedal??
no, don't do it that way, now there's no money for gas and rent.
Seriously though, can you get that booster in there and close the hood?
I put C5 brakes on my 86, and it stops pretttty darn good now........
the way a corvette that weighs 3100 pounds should stop!!
Well that wasn't cheap. It should stop on a dime from 150 and give you back $0.09
What diameter rings did you get??
I forget is this drag racing only car? I remember your rear end build out post.
Yea it will fit but the bolt pattern is different.
They are 14x1.25 It's a daily driver!!!
Got the rotors together.
ok, that just looks mean!!!!!!!
With the 19" rims aren't you worried that the really tiny sidewall will cause issues at the track?
Received 1,768 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Stunning!! Absolutely stunning!! Those calipers really stand out, but not too much (if that makes any sense). Perfectly accented.
Wanna drive up and do my car? Ohio isnt too far for you.
