check out my fuel tank!
I posted a couple weeks ago about having the common C4 problem of fuel starvation during autocross, recently it happened with 3/4 of the fuel left. I pulled the assembly out today but didnt see anything that looked too bad. A couple wires have some bare spots but there is nothing that I see they could ground themselves too. I'm planning on replacing the wire harness as well as the sock. Here are pictures of the inside of my tank and the pump assembly, let me know if you see anything that you think should be addressed or any other ideas.
replace that nasty filter sock
Clean it all up, if you want to replace it racetronix has a great pump replacement kit!
Fuel cell.
Make sure when the new sock goes on the new pump that it is orientated correctly (long end towards the rear of the car - yours is correct in the photo). Use a couple of black zip ties (tie wraps) to secure the fuel pump's wires (power & ground) to the steel intake tube....this will keep the sloshing fuel from wiggling the new wires/connector as much on the old harness (probably why you had insulation bare spots).
Slingshot
That's interesting; I never knew that there was a proper position orientation for the sock. What happens if it’s supposedly positioned incorrectly?
PS: Skip testing/installing pulsator and just install a short length of high pressure fuel injection hose there instead. Most aftermarket fuel pump kits some with a short length of hose for this purpose.
I installed the new sock and addressed some wires that were a little loose, ordered a new harness but that wont be here till next week so I just put wire clamps on them to get rid of the bare spots for the time being. When removing the pump we noticed that some of the bolts were broken, and didnt think much about it. Got home from filling the car up with gas and saw that the part that bolts to the pump assembly to the fuel tank was leaking under pressure. Any ideas how to get broken/stripped bolts out of the fuel tank aside from drilling?
For the ones that are stuck use some needle nose "vise grips" to grab the bolt heads - once "locked on" pull up while twisting counter clockwise.
Use caution when working on semi - open fuel cells
I'm changing my pump in a few days so that's why I'm asking.
Joel
Test if you don't trust it:
Put some gas in a jar - insert a tie wrap into jar filled with gas - cap off the jar....wait to see what happens.
