Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-18-2011, 08:10 AM   #1
GSjoe
Junior Member
Default How to Replace a Dimmer Switch Actuator
When lowering the steering column of a friend's 1991 to remove a faulty instrument cluster, the dimmer switch rod became detached. After attaching the rod to the dimmer switch at the lower end of the column, the multi-function lever was still floppy and did not operate the dimmer at all. Upon removing the end cap below the multi-function/turn signal lever, a plastic piece literally fell on my face, as did a small piece of plastic which had broken off the larger piece. The larger piece was the actuator and I was able to buy a new one at the local Chevrolet dealership. The problem, however, is how do I put this thing back in place. I've all but given up trying to insert it from the area below the turn signal switch where it came from. I've checked the shop manual, but the directions for this little plastic actuator are not really clear to me. How do I replace this part? Do I need to remove the steering wheel, etc? Please help if you've ever done this job. Thanks in advance for any assistance you can provide.
GSjoe is offline   Reply With Quote
Old 07-04-2011, 03:14 PM   #2
articvett
CF Senior Member
Did you ever figure out how to replace the dimmer switch actuator?I need to do this on a 1992 chevy truck.Any advice would be great.
Thanks Joe
articvett is offline   Reply With Quote
Old 07-05-2011, 07:55 AM   #3
GSjoe
Junior Member
Yup, we figured it out, and it really wasn't a bad job. Once the steering wheel is off it all becomes clear. My friend, the owner of the ZR1, and I did it all in a bit over an hour and a half. We started by disconnecting the battery and leaving things at that for about an hour while we had lunch. That gave time for the airbag capacitors to lose their charge etc. reducing the risk of deployment. Disconnecting the airbag plug at the base of the steering column--first taking off covering panels, of course--removing two screws on the backside of the steering wheel and disconnecting the connection at that end allowed us to remove the airbag. Removing the steering wheel nut was next, and then came the steering wheel itself using a small puller. Next came the locking plate--again with the right tool to depress it to allow removal of the snap ring that holds the locking plate in place. Once that was out of the way, the place where the actuator went was obvious. In just a matter of minutes it was in place, and everything went back together easily. All in all we fretted over doing this job far more than we needed to. It's really pretty simple.
Old 07-05-2011, 09:23 AM   #4
jeffp1167
CF Senior Member
jeffp1167's Avatar
A bad tilt knuckle or worn pivot bushings will cause the dimmer switch to have issues working and also cause that rod to keep falling out.
jeffp1167 is offline   Reply With Quote
Old 01-15-2013, 09:22 PM   #5
Cary Lamari
Junior Member
Cary Lamari's Avatar
I figured out how to reinstall the dimmer actuator without taking the steerig wheel off. I did have to take the tilt lever off to get better access to where the actuator goes in and had to loosen the dimmer switch itself to have room for the rod to move freely. and after I set the actuator in place noting that the multi purpose turn signal switch moved the actuator with my left hand i pushed the rod up toward the wheel so it had tension on the actuator then I put the cover back on. The cover is the only thing that holds the actuator in place which is the difficult part, holding tension on the rod so the actuator doesn't fall out again while reinstalling the cover. and finally I readjusted the dimmer switch on the colum and it all came together. Took a few hours to figure it out. Once you understand how the actuator fits into the turn signal switch it becomes apparent.
Cary Lamari is offline   Reply With Quote
Old 12-23-2013, 11:01 AM   #6
abedj
Junior Member
Default Dimmer Switch Actuator
Hello. I saw your post and am stuck at this point in putting my steering wheel back together. That actuator is the last piece. do you recall how you put the plastic piece (actuator) and kept it in place while you put the cover back one?
Dan.
Quote:
abedj is offline   Reply With Quote
Old 12-23-2013, 11:51 AM   #7
Cary Lamari
Junior Member
Default reinstalling the actuator
Quote:
Dan.
You lossen the dimmer switch on the column there are two small bolts or screws, you put the rod in place then slide the actuator in from the top till it makes contact with the rod then tighten the dimmer while holding the actuator rod and then reinstall the cover. then reinstall the steering wheel . Thats how I did it. took hours of trial and error to figure it out. but after it became easy. I remember having to do it a couple times till i got it but wasn't that bad once the steering wheel is off pushing the actuator down from the top. You can slide the actuato from the bottom up and push the rod to hold it but that is a little tricky,pushing the plastic actuator from the top is the easiest way. remember to hold the rod with your left hand pushing up, keeping tension on the rod till you get the dimmer re-attached. The dimmer puts tension on the rod holding the actuator in place if that moves it will fall out again.
Reload this Page How to Replace a Dimmer Switch Actuator
Tags
1991, actuator, broken, c4, camaro, corvette, dimmer, dimmerswitch, firebird, replace, replacement, rod, suburban, sw, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
