tires
I believe this is one of the best tires for the money. I purchased these after seeing them on one of the forum members cars and couldn't be happier with them.Can't beat the price.....WW
http://www.tirerack.com/tires/tires....Model=HTR+Z+II
Nothing wrong with the "gold" line or Bendix brake pads for street driving. Ceramic creates less dust and costs more. Other "exotic" materials exist heading well above $100/set.
Pick according to your needs. Most anything will work for normal street driving.
Thats my take on it anyway
Also are you using the the HTRZ (Block pattern tread) or the HTRZ+II( Y tread pattern)
Kumhos
Kumhos are good also. I have 35,000 miles on my rear. The fronts would have been fine also but my alignment went out.
I now have Poly bushings front and rear on my 96.
sumi 315's run over an inch narrower than other 315's, closer to 285/305, I have them on 11's but they would be fine on a 9.5 rim. wouldnt run a full measure 315 but dont see an issue with the sumi's. I also have the 275's on 9.5 they are closer in width to other makers.
Yeah I am running the 11" rims and the tires are the HTRZ's, block pattern. Looks really sweet from the back with those fat a** tires.
