Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2011, 10:25 AM   #1
boonie c4
CF Senior Member
Default How do I install Freon 134 to charge my AC
My AC repair man present me with a 2 fold solution to a contional AC leak problem that i've been experienceing with my 94. 3 years ago i'd had my Corvette's AC rebuilt now i'm experiencing a leak that drains the system every year. My AC repair man's solution was to pay him $1k to find and fix the leak or just pay him $100 every year to refill the system. sothen I went down to Walmart and bought a 3lb can of 134 Freon for $25.00" the Freon comes with a gauge + install hose" so that I can refill my car myself. question is: how do I refill or install the Freon into my Corvette?
Thanks Boonie
boonie c4 is offline   Reply With Quote
Old 05-08-2011, 10:39 AM   #2
twin540
CF Senior Member
Support Corvetteforum!
twin540's Avatar
Do you have any refrigerant in the system right now? If you don't you're going to have to pull a vacumm to remove non condensables (air) from the system. If you do have pressure you'll be okay to charge.
twin540 is offline   Reply With Quote
Old 05-09-2011, 09:52 AM   #3
RedBowTies88
CF Member
subscribed....
RedBowTies88 is offline   Reply With Quote
Old 05-09-2011, 10:01 AM   #4
c4cruiser
CF Senior Member
c4cruiser's Avatar
$1K to "find and fix" the leak??? It's time to find a shop that will charge a reasonable rate and do the work right. A good shop will charge the system and insert a dye to find the leak. Once that is done and the leak found, then an accurate estimate of repairs can be provided to you.
Simply tossing in more refrigerant does not solve the problem. As mentioned, if the system is completely empty, a vacuum will have to be established to get the system to even accept refrigerant.
Find a good shop and have it done right so you can avoid the same problems next time.
c4cruiser is offline   Reply With Quote
Old 05-09-2011, 11:06 AM   #5
Paul Ruggeri
CF Senior Member
Paul Ruggeri's Avatar
If you want to bring your car to me I can charge it with R134 that has dye in it. When it leaks I'll be able to see where the leak is. The shop # is 916-972-8358. It won't cost $1000.
Paul
Paul Ruggeri is offline   Reply With Quote
Reload this Page How do I install Freon 134 to charge my AC
Tags
1997, 98, ac, add, air, c4, car, charge, conditioner, corvette, cost, freon, hose, insall, install
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
