TCI 6X Trans into an '86?
Received 3,043 Likes
St. Jude Donor '05
Now this I would like to see done!!
Even if you had to cut the tunnel and mod the mount it would be worth it.
I'm a little slow. What is a TCI 6x?
Your tranny is still holding up nicely btw.
I'd expect the gear ratios would have alittle wider spread. It's really a close ratio 6spd auto, probably good for aceeleration but less overdrive for high speed cruising then a th700r4. For that money you'd expect to have a .50 overdrive ratio.
