Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2011, 11:26 AM   #1
corvette95
CF Senior Member
Default 89 a/c low pressure line freezing up
My low side is freezing up. I did replace compressor couple months ago. Changed orifice tube and pulled a vacuum. What causes line freezing?
corvette95 is offline   Reply With Quote
Old 04-25-2011, 12:26 PM   #2
SunCr
CF Senior Member
Low Pressure Switch should open at 25 psi to prevent the ice (assuming it's still R12). It's either defective or needs to be adjusted. There's a screw between the terminals of the switch. Turn it clockwise to raise the cutoff threshold. To check it out, hook up your Manifold Gage set and put the a/c on Max. Pull the Blower Motor connector and the pressure should drop. Note the low side pressure when the compressor cycles off. Remove the Low Pressure harness from the switch and turn the screw a 1/2 turn and recheck. If it doesn't change anything, get a new one. Note: the new Switch may be set for R134 which is a 22.5 psi threshold. That's too low and it will have to be adjusted to 25 psi to prevent the icing.
SunCr is offline   Reply With Quote
Old 04-25-2011, 12:37 PM   #3
corvette95
CF Senior Member
Its still r12. I will check the #'s and that switch and post findings! Thxs!
Reload this Page 89 a/c low pressure line freezing up
Tags
ac, freeze, freezes, freezing, frosting, icing, line, lines, low, mobil, orifice, preesure, pressure, side, tube
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
