<*> The Official DIY, Tech Tips, FAQ and where did my sticky go?? Thread UPDATED!!
Old 04-19-2011, 08:42 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default <*> The Official DIY, Tech Tips, FAQ and where did my sticky go?? Thread UPDATED!!
In an effort to clean up this section I have taken and consolidated all those old stickies here:
Links to Old Tech Tips
http://forums.corvetteforum.com/c4-t...tions-too.html
The Official Timeslip Thread
http://forums.corvetteforum.com/c4-t...ip-thread.html
Injector Videos and Questions
http://forums.corvetteforum.com/c4-t...questions.html
My 700 R4 Build
http://forums.corvetteforum.com/c4-t...-r4-build.html
LT-4 Suspension rebuild
http://forums.corvetteforum.com/c4-t...-pictures.html
Pete K is building me a 383
http://forums.corvetteforum.com/c4-t...-w-photos.html
Headlight Repair
http://forums.corvetteforum.com/c4-t...air-w-pic.html
LT-4 383 Rebuild w/pics
C4 Tech summary and FAQ
http://forums.corvetteforum.com/c4-t...lar-basis.html
The build up resumes PLRX LT-4
http://forums.corvetteforum.com/c4-t...-plrx-lt4.html
92 Auto Tranny Shift Cable
https://www.corvetteforum.com/forums...ift-cable.html
Completed ZF6 swap
https://www.corvetteforum.com/forums...-zf6-swap.html
Hand Brake lever stuck up
https://www.corvetteforum.com/forums...-stuck-up.html
How to remove radiator- late C4
https://www.corvetteforum.com/forums...r-late-c4.html
Pwnage's 383 Build (Pics!!)
https://www.corvetteforum.com/forums...uild-pics.html
How to Remove and Replace Passenger Side Oxygen Sensor 1994 Corvette C4 LT1
https://www.corvetteforum.com/forums...te-c4-lt1.html
How I fixed my tilt steering wheel -pics
https://www.corvetteforum.com/forums...pictorial.html
Add a Drain Plug to Your 700r4/4L60/4L60E
https://www.corvetteforum.com/forums...l60-4l60e.html
84-89 C4 heater core replacement hint
https://www.corvetteforum.com/forums...ment-hint.html
94AC HVAC Problem
https://www.corvetteforum.com/forums...c-problem.html
How To Repair your Range, Miles, etc, button assy
https://www.corvetteforum.com/forums...tton-assy.html
How to Reset The 90-96 Change Oil Light
https://www.corvetteforum.com/forums...oil-light.html
Video How To: 90-96 Heater core replacement without dash removal.
https://www.corvetteforum.com/forums...h-removal.html
94-96 Sport Seat wiring tips
https://www.corvetteforum.com/forums...ring-tips.html
rattle trap (10-24-2016)
Old 06-24-2011, 06:27 PM
KeviKev
2nd Gear
KeviKev's Avatar
Does anyone know if tires and rims off a C5 will fit on a C4 1988?
Billygoatkid (05-08-2021)
Old 08-26-2011, 11:32 PM
Rocket-J
Rocket-J's Avatar
Default LT1 to LS1 coil per cyclinder swap.
anyone wants all the details to installing Bailey's LTCC coil per cylinder on a 94 C4, I have most the answers now. My conversion had a few glitches and I soak in a bunch of info from every source I could.
It might be nice to put it all in one place. It would have been a lot easier.
Old 10-28-2011, 04:24 PM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default SIDESKIRT DIY 10-2011 part 1
Looks like there has been enough interest to post this in the official DIY thread....here you go and best of luck!
Jerry
http://forums.corvetteforum.com/c5-g...-part-1-a.html
Old 02-06-2012, 12:07 AM
drumchum
drumchum's Avatar
KeviKev, I bought my first C4, as my second project car. Its an '85 and came stock with 2004 C5 corvette rims/tires. They not only fit well but look amazing.
Hope this helps
Old 06-18-2013, 12:49 PM
Captin21
Captin21's Avatar
I'm useing c6 rims and tires on mine I had to buy 1 inch billet spacer plates do not cheep out on these I went to a very good manufacturer cannot remember the name but I could find it these plates bolt on your existing lugs comes with nuts you lock them down at about 100 ftlbs with locktite and then use the lugs off the billet plates I also bought special lugs so all 10 are impossible to get off without the special socket . The size is 19 x 9.5 in the front and 20 x 10.5 rear they look soo nice on it . Mine was a z 52 to start so it took them well I think the bace would be fine too
Old 10-22-2013, 08:43 PM
bdw18_123
bdw18_123's Avatar
Location: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
Default Optispark failure & fix info
I thought I'd add a link to a thread I started in 2009 on an opti issue I had. Since the '92 to '94 opti's have such a high failure rate, I figured having this link here could help others who run into this issue.
Installing the active venting system that the '95 and '96 Corvette opti's have will go a long way to increasing the reliability of the earlier, passive vent opti's.
http://forums.corvetteforum.com/c4-t...ral-times.html
Old 01-24-2014, 02:58 PM
corvetteronw
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default L98 No Start info
http://www.digitalcorvettes.com/foru...d.php?t=101921
Old 05-17-2014, 03:53 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I'm finishing up repair of the RH motor/gear on my '88. Turns out the OEM Delrin bushings were like new; finally I realized that the nylon gear had split and was hanging up the motor.
I had to pull the motor shaft to remove the OEM gear and found that thread wrapped around the thiick copper wires allowed me to secure the brushes against spring tension while lowering the motor shaft back into the housing with the new Nylon gear.
Here is a "how to" that contains pictorals on the procedure. I found this useful as I could take my "book" down to the car for easy reference.
Old 01-27-2015, 09:49 PM
kenpeindl
kenpeindl's Avatar
Default Sport Seat Lumber Bladder Replacment Link
Here is a link to my post on replacement of the lumber bladders.
https://www.corvetteforum.com/forums...placement.html
Old 07-13-2016, 12:01 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Thanks for this consolidation.
Old 05-14-2017, 05:51 AM
Stephanos
2nd Gear
Stephanos's Avatar
Default Manual headlight raise 1984 corvette
All
Trying to workout how to manually raise headlight on an 86 corvette. The version of the headlight motor does not have the **** that can be turned and I can't find a manual that provides advice. Any ideas.
Thanks in advance
Old 11-02-2017, 02:33 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Originally Posted by Stephanos
I'm trying to workout how to manually raise headlight on an 86 corvette. The version of the headlight motor does not have the **** that can be turned and I can't find a manual that provides advice.
This was posted in the wrong place, so it's an old post, but I'll answer it anyway, in case someone has a similar problem. The '84-'87 headlight motors have the manual control ***** on the bottom of the motors. The '88-'96 have the ***** on the top.
Old 11-02-2017, 02:45 PM
Hot Rod Roy
Default Targa Top Re-Bonding
The acrylic or fiberglass tops of our C4's have a bad habit of coming loose. This needs to be fixed ASAP before you become a member of the FRC (Flying Roof Club)! I successfully re-bonded my acrylic roof in 2006. I tried several procedures with weather seal adhesive, epoxy, and RTV, all of which were very short term fixes. Here's the link (date: 9-30-13) to the right answer!
https://www.corvetteforum.com/forums...ir-advice.html
(My roof repair has been tested in HOT weather, and at 125 mph.)
Old 11-28-2017, 02:39 PM
Hot Rod Roy
Default '84 Heater Control Vacuum Solenoid
The '84's have a common problem with a failing heater control vacuum solenoid. Here's my economical answer for this expensive part:
https://www.corvetteforum.com/forums...ter-valve.html
Old 02-02-2018, 02:47 AM
Hot Rod Roy
Default '84-'87 Headlight Gears
Here's a link to Cliff Harris' detailed procedure, with photo's, for the early ('84-'87) headlight gear repair. The early motors have the manual control **** on the bottom of the motor.
Old 07-10-2018, 01:12 AM
ETM
ETM's Avatar
Is there a way I can be sure what paint code my car is? Just gotta touch up a small area.
To <*> The Official DIY, Tech Tips, FAQ and where did my sticky go?? Thread UPDATED!!
Old 12-03-2020, 11:50 AM
Joe K
Joe K's Avatar
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Default How To: Repair Loose Steering Column
Something I wrote. Hope you find it useful.
Thanks for looking,
Joe K
Old 01-21-2022, 09:44 PM
LogMofLT1
3rd Gear
LogMofLT1's Avatar
hi new to the forum but I have a 94 and am looking at the jet under drive pulley has anyone else done this to their c4 as well as knowing the ratio of under drive, on the website it just states performance ratio.
Old 11-04-2023, 11:41 AM
HudsonFruechting
1st Gear
HudsonFruechting's Avatar
Default Need help!!!
Hey, so I'ce have been working a lot this summer and I am 15 years old, got my first car this last month (1984 Corvette) and I am in the process of replacing all of the weather seals, I first ordered some generic brand of weather seals for it and now the door doesn't shut. I googled a couple of tips and I think they just don't fit, does anyone know where to get some seals that will actually fit my car. I need to get this done before the snow comes in. If anyone knows a brand or place to buy from please respond. Thank you!
Quick Reply: <*> The Official DIY, Tech Tips, FAQ and where did my sticky go?? Thread UPDATED!!
