A couple of questions for the Experts & others..
Never heard of injectors increasing power. Match the injectors to the power you have. If the stock injectors are bad you would know it in other ways, hard start, stumble, etc. Start with the basics like a good tune first before you start tossing money at it. New injectors will smooth it out if thats a problem but will not increase power output.
Replace the Multecs with Bosch III's. Talk to Jon at Fuel Injection Connection. He'll fix you up right. And, get the gasket set from him, too. His O-rings are ethanol-proof.
As I said to another poster, while you have the plenum off, replace all the O-rings, the diaphragm in the F.P. regulator, and the E.G.R. valve. The Manifold Air Temperature sensor, too, if you want. I replaced the fuel filter and fuel pump, too. Nothin' but pure, clean 93 octane flowin' through my new injectors.
Put the car up on jackstands and take the wheels off so you can stand in the wheelwell. Much easier on your back. Trust me on that one.
Mike
'90 'vert
Mike
'90 'vert
ok, found the timing marks. But there does not seem to be and number on it ? like on most of the others ? and it does not seem that dirty ?
You might want to check for tdc and make sure the balancer is not slipped on the hub so that thiming will be wrong even if the numbers line up. the PO might have set the timing with it this way even you did not.
Dave
Dave
