fouling spark plug
Old 04-17-2002, 01:42 PM
PonyH8R
PonyH8R's Avatar
Default fouling spark plug
I have a question, my vette is at around 153K miles and the number eight spark plug gets fouled up after a few hundred miles. Is there a spark plug that works better when your engine starts to burn oil? Can I increase the spark? Just not ready for a rebuild yet.
Thanks!!
Old 04-17-2002, 01:57 PM
ZylaRace
ZylaRace's Avatar
Default Re: fouling spark plug (kghott)
Could try a hotter plug, but I don't think this will get you very far.
You could look into doing the valve seals on that cyl. If it is fouling that quick, it is probably the valve seal. The intake side.
Old 04-17-2002, 02:02 PM
scorp508
scorp508's Avatar
Upon disassembling me engine I noticed a trend. Cynlinder #2 was the most carbon'd up and had the most burned oil inside the head. Plug #2 was also very fouled. I had a skip at idle, and blue smoke at startup.
Well, upon pulling the rockers I noticed that one of the locks on exhaust valve #2 was mangled and the valve was ready to drop. :eek: I bet that was the cause of the skip, oil leak, and anything else wrong with that cylinder. :)
Old 04-17-2002, 02:36 PM
PonyH8R
PonyH8R's Avatar
Default Re: fouling spark plug (ZylaRace)
Is that a tough procedure to do with the valve seals? That side of the engine is pretty easy to get to for the most part. Any cost estimates?
Thanks for all the info guys.
Old 04-17-2002, 02:47 PM
jtjerry
jtjerry's Avatar
I have the same, but I was first :)
check my post "Injector or valve?" (few days ago)
Jerry
Old 04-17-2002, 03:06 PM
NUckINg FuTS
NUckINg FuTS's Avatar
You can try going to a higher weight oil?
Old 04-17-2002, 03:57 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I did valve seals in the parking lot. No compressed air so I fed rope into the cylinder near TDC to keep the valves up.
Scrop says the right side valve cover is easy to remove on his '87 so should be on your '86. If you only do the #8 cylinder you could set the lash cold and it should be a cake job. It's a little hard to turn the crank by hand with all valve springs set, even with the spark plugs out, but can be done.
Old 04-17-2002, 03:58 PM
scorp508
scorp508's Avatar
Yes, 86 has the same setup as 87 does. Unplug your injectors and try to get the harness out of the way. Then the passenger valve cover should come up easily.
Old 04-17-2002, 06:49 PM
jtjerry
jtjerry's Avatar
Default Re: (scorp508)
not so easy, not so easy,
it is do-able job :) but not so easy, you will see...
Jerry
To fouling spark plug
Quick Reply: fouling spark plug
