What Does the Rear Passenger Side Oxygen Sensor on a 94 LT1 Do?
Old 03-29-2011, 08:50 PM
Sidney004
Sidney004's Avatar
Default What Does the Rear Passenger Side Oxygen Sensor on a 94 LT1 Do?
Its an OBD1 car, the drivers side has an Oxygen Sensor before the cat, yet the passenger side has one before the cat and one after.
Old 03-30-2011, 09:49 AM
-=Tom=-
-=Tom=-'s Avatar
I often wondered the same thing. I would suspect it has something to do with monitoring the exhaust before and after the cat but then why wouldn't it be on both sides?
Old 03-30-2011, 10:03 AM
PDQUIK95
PDQUIK95's Avatar
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
The rear passenger O2 sensors on 94 and 95 vettes only can be removed or disconnected without any codes being set.You could use it as a spare if needed when 1 of the fronts go out. This was just part of the pre OBDII change over for 96 when both rear O2's were required and would need to be tuned out or simulators installed to keep from setting a code.
Rick
Old 03-30-2011, 10:32 AM
proracr
proracr's Avatar
IMHO, the logical explanation for the O2 sensor after the cat would be for the purpose of monitoring the effectiveness/proper operation of the cat by providing a before and after O2 level to the ECM.
Old 03-30-2011, 10:35 AM
STL94LT1
STL94LT1's Avatar
It does pretty much NOTHING!!
Old 03-30-2011, 12:35 PM
fc_soldier
Support Corvetteforum!
fc_soldier's Avatar
Originally Posted by proracr
IMHO, the logical explanation for the O2 sensor after the cat would be for the purpose of monitoring the effectiveness/proper operation of the cat.
Old 03-30-2011, 06:12 PM
Sidney004
Sidney004's Avatar
But only on one cylinder bank?
Old 03-31-2011, 02:37 AM
tpi 421 vette
tpi 421 vette's Avatar
It's just checking to make sure the cat is doing it's job. Only one will tell the story, and it's less money the manufacturer has to spend.
Old 03-31-2011, 10:21 AM
Sidney004
Sidney004's Avatar
I don't have cats anymore and it didn't throw a code!
Old 03-31-2011, 10:38 AM
STL94LT1
STL94LT1's Avatar
It won't.
Old 03-31-2011, 02:44 PM
jmgtp
jmgtp's Avatar
Agreed, removed it from my 94 and welded the hole closed. No codes.
To What Does the Rear Passenger Side Oxygen Sensor on a 94 LT1 Do?
Quick Reply: What Does the Rear Passenger Side Oxygen Sensor on a 94 LT1 Do?
