Bronze Brush ?
It will probably be brass not bronze and a quick google for brass brush turns up thousands of hits. Most hardware stores will have a wood handled variant, many welding supply shops as well (used on certain metals where steel wired brushes will cause welding problems.)
By the way, if you do go for a hardware store brush, take a magnet with you. I needed a brass brush to solder aluminum and found out the hard way the first one I picked up was simple brass plated steel bristles..
Slingshot
I found what I think is a close version of this brush at McMaster-Carr. I'll see how close it is when I finally receive it.
I hope to use the brush to clean up aluminum suspension parts. We'll see.....
