Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2011, 04:44 PM   #1
midweekwarrior
CF Member
Send a message via AIM to midweekwarrior
Default 92 LT1 stalling issue?
hey so on the way to savannah this past weekend i ran over a 18 wheeler tire at about 77mph (ouchies).
Long story short, there was no damage as i could tell but today (monday another ouchies) my car cut it self off as i was accelerating form a dead stop and lost oil pressure.
Any ideas or troubleshooting tips would be much needed =)
PS, my 1972 stingray is almost done, needed a new daily driver...
midweekwarrior is offline   Reply With Quote
Old 03-21-2011, 06:31 PM   #2
92ragtop
CF Senior Member
92ragtop's Avatar
Hard to believe you hit a tire that size and didn't sustain any damage. I assume you have full oil in the crankcase? If not, I'd look for puncture damage to the oil cooler or the oil pan. If you've got oil in it, but no pressure, then I've got no suggestions.
92ragtop is offline   Reply With Quote
Old 03-21-2011, 09:52 PM   #3
pcolt94
CF Senior Member
pcolt94's Avatar
Quote:
THEN
I would say start looking at the sensors and wiring. Look at some of the electrical and check as much as you can
Offhand if you really lost oil pressure, that might be a reason why the engine stopped because you could have lost power to the fuel pump from the pressure switch….Just a thought
If you are really worried about oil pressure get mechanical gauge for test. (what a pain)
If the oil pan is squashed, it may affect the oil pick up.
pcolt94 is offline   Reply With Quote
Old 03-22-2011, 07:31 AM   #4
midweekwarrior
CF Member
i got engine codes 16 and 32 offa my system =/. It has oil, no damage to the oil pan etc... It still drives, just gotta get it going.
after looking at the codes im thinking it's some wiring lose in the front that connects the distrbutor. . maybe that opti w/e wire.
Old 03-22-2011, 08:12 AM   #5
Z06_BluByU
CF Senior Member
Z06_BluByU's Avatar
there is a wire to the digital oil sensor on the underside of the engine above the oil filter.. make sure it didnt get ripped out/damaged..
Z06_BluByU is offline   Reply With Quote
Old 03-22-2011, 08:58 AM   #6
78pacer
CF Senior Member
78pacer's Avatar
Wow...an 18 wheeler tire. Damn. I got a real bad visual on this one. How far down the road did you push it, and how did you get it dislodged?
Mike
78pacer is offline   Reply With Quote
Old 03-22-2011, 11:26 AM   #7
jaa1992
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
OK, you have the dreaded opti codes! Check the harness and connections from the opti to the connector on the passenger side.
One end or the other could be loose, or not making good contact.
Also check the connections on the ICM and coil (front side of passenger head.
Good luck, hope it is that simple!
jaa1992 is offline   Reply With Quote
Old 03-22-2011, 10:19 PM   #8
midweekwarrior
CF Member
yeah, opti spark it is.. from my deductions. I checked the wiring voltages, and got my 12 hot and 5. (my friend has a LT-1 caaammmmaaarrrrooo - we call it loud varoom)
I figured out how to stall it on que as well.
>Dead stop and hard accel, i got a short miss and then car died.
Anyone got any other ideas?
Getting a new opti. I'll post some pictures or something as i tear into it.
Thankfully, the car drove all the way to savannah and back with only one stall after the tire incident. No pushing either, or tire to take out, i managed to luck out.
Reload this Page 92 LT1 stalling issue?
Tags
16, 1992, 92, c4, code, corvette, engine, issue, lt1, stalling
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
