Hesitation/bogging/rough idle in 89
Old 03-19-2011, 05:39 PM
jameyemail
Navigator
jameyemail's Avatar
Default Hesitation/bogging/rough idle in 89
Just replaced the injectors....egr cleaned. Everything back together nicely. It was running like crap prior. Seems to have more power...but serious hesitation when stepping on the gas (especially under load)...some popping. Any ideas? Suggestions?
Thanks!
Old 03-19-2011, 05:47 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
Checking/pulling "stored" ECM codes is pretty easy and a good place to start.
ex-x-fire
ex-x-fire's Avatar
Do a fuel pressure test.
Old 03-19-2011, 05:54 PM
jameyemail
Navigator
jameyemail's Avatar
if there was a trouble code...wouldnt the "check engine" light remain on?
Old 03-19-2011, 06:00 PM
engle1147
engle1147's Avatar
Depends on the "trouble" but not always.
Old 03-20-2011, 04:46 AM
corvette95
corvette95's Avatar
New injectors not seated fully?
Old 03-20-2011, 11:32 AM
AGENT 86
AGENT 86's Avatar
Good place to start.
Old 03-20-2011, 11:36 AM
jameyemail
Navigator
jameyemail's Avatar
they seem to be seated....but how can I really tell? I mean, the rails are all bolted down, etc.
Old 03-20-2011, 11:46 AM
corvette95
corvette95's Avatar
cant tell NOW but when they go in, make sure they snap top and bottom positively, also, make sure the old orings come off, they will fit in with two orings (by mistake) on top of bottom,and they wonr really leak enough to tell.
Old 03-20-2011, 12:34 PM
jameyemail
Navigator
jameyemail's Avatar
So I can move them up and down slightly...should they be seated to the block as much as possible? (feel kinda stupid...just have never messed with injectors)
Old 03-20-2011, 04:52 PM
corvette95
corvette95's Avatar
with them installed and the ruel rail tight, they should barely move (twist left or right) zero up and down.
Old 03-20-2011, 07:34 PM
MotorCity_87_C4
MotorCity_87_C4's Avatar
Have you disconnected your battery after replacing the injectors?
Old 03-20-2011, 09:48 PM
jameyemail
Navigator
jameyemail's Avatar
it was disconnected while I replaced them...but not since. ????
Old 03-20-2011, 10:08 PM
95fxdwg
95fxdwg's Avatar
Default new injectors
remove negative battery cable , and turn headlight switch on TO COMPLETELY DRAIN ANY RESIDUAL VOLTAGE FROM THE ELECTRICAL SYSTEM ,ecm and radio capacitors can carry enough residual voltage to NOT CLEAR ALL THE CODES , I just did my injectors today and it WORKED FOR ME
Old 03-23-2011, 08:58 AM
jameyemail
Navigator
jameyemail's Avatar
So I finally changed the S.O.B. fuel filter....and cleared the codes. And no "check engine" came on. Seems to run a little better...except for that hesitation/bogging when you put your foot into it... starting to kinda **** me off!
Old 03-23-2011, 10:58 AM
MyFirst90coupe
MyFirst90coupe's Avatar
Did you check the fuel pressure? I did my injectors and then a couple weeks later the fuel pump crapped out. It can be tricky, my pump would work ok when it was cold but once it warmed up a little forget about it.
Old 03-27-2011, 04:20 PM
jameyemail
Navigator
jameyemail's Avatar
It's the other way...when it is cold it runs like crap (bogging when you stomp on it...rough idle). What is weird: so it's running/idle rough...I disconnect the MASS AIR plug sensor plug...it seemed to run better. ???? Any ideas?
Old 04-02-2011, 11:22 AM
jameyemail
Navigator
jameyemail's Avatar
Default Thank You Everyone!
Thanks to everyone for all of the suggestions!
Old 04-02-2011, 12:11 PM
cadwiz_01Z
cadwiz_01Z's Avatar
Location: When Democracy becomes tyranny, the armed citizens will still get to vote!
Did you get this figured out? If it runs better with the MAF unplugged, I would think that it is sending bad info to the ECM. Had similar situation with mine and went away with a new MAF.
To Hesitation/bogging/rough idle in 89
Quick Reply: Hesitation/bogging/rough idle in 89
