Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-10-2011, 05:32 PM   #1
westgl
Junior Member
Default Dana 36 vs 44 Rear End
What is the difference between the Dana 36 & 44,
Weaknesses and strengths or Pros & Cons
I bought a rear end, i thought it was a Dana 44, it turns out it is a 36.
I will be running a 350ci engine around 320h.p. & 380ft lbs torque with a Automatic Trans. & maybe changing from 3:07.1 to 3:54.1 gears.
It will be a daily driver.
Seems like a lot of people here have changed or are changing from the Dana36 to a Dana44.
Can a Dana36 Rear end, live with a auto trans and mild 350 V8?
I Inspected my Dana 36, and noticed the spider gears are missing most of their teeth.
Any feed back would be appreciated
Westgl
westgl is offline   Reply With Quote
Old 03-10-2011, 05:50 PM   #2
JackDidley
CF Senior Member
JackDidley's Avatar
44 has 8 1/2" ring gear, 36 is more like 7 3/4. The Dana 36 should be fine at your power level. Hard launches on slicks will kill it though. While you have it apart replace the clutch pack. They do wear out.
JackDidley is offline   Reply With Quote
Old 03-10-2011, 07:05 PM   #3
WW7
CF Senior Member
WW7's Avatar
You do read here once in awhile about someone blowing a D36, D44s not to often, and if they do, its because of big HP and big slicks...WW
WW7 is offline   Reply With Quote
Old 03-10-2011, 07:40 PM   #4
TA
CF Senior Member
TA's Avatar
On the street you'll be fine
If you go to the track with sticky tires you could be in for a problem.
TA is offline   Reply With Quote
Old 03-10-2011, 07:47 PM   #5
87 vette 81 big girl
CF Senior Member
You will be fine on the street with the Dana 36 7-7/8" ring gear C4 diff.
Use a GL-5 or GL-6 rated gear oil.
I prefer synthetic gear oil.
Mineral - dino gear oil ok too.
Don't forget the GM Limited slip additive from your local GM dealer.
Need 1 bottle of that additive for the Posi-traction unit.
Brian
87 vette 81 big girl is offline   Reply With Quote
Old 03-10-2011, 08:29 PM   #6
rodj
CF Senior Member
rodj's Avatar
http://forums.corvetteforum.com/c4-t...er-limits.html
http://forums.corvetteforum.com/c4-t...ic-limits.html
rodj is offline   Reply With Quote
Old 03-10-2011, 09:18 PM   #7
westgl
Junior Member
Default Rebuilding my Dana 36
Thanks for your responses,
I need to rebuild my Dana 36,
Looks like i need a few parts, But where is the best place to get the parts i need.
I know about, JustDifferentials.com.
Are there any others?
I need;
Spider gears kit,
Clutch pack,
Bearings,
Gaskets,
or maybe a complete rebuild kit?
Thanks Again
Westgl
Old 03-10-2011, 09:22 PM   #8
CF Senior Member
I need;
Spider gears kit,
Clutch pack,
Bearings,
Gaskets,
Thanks Again
Westgl
Buy a Master rebuild kit.
Will have all bearings, shims, ect.
Buy a dana 36 positraction clutch pack.
Only buy spider gears or side gears if yours are heavily worn or trashed.
If yours are in nice condition yet, reuse them.
Brian
Old 03-10-2011, 09:24 PM   #9
C409
CF Senior Member
C409's Avatar
..... Guys the OP has already hatched his Dana 36 ... go find a Dana 44 and do burn-outs with confidence ............
C409 is offline   Reply With Quote
Old 03-10-2011, 09:30 PM   #10
CF Senior Member
Quote:
Need $$$. lol
Good luck finding a C4 Dana 44 with batwing, driveshaft, C-beam for $400 or less.
Not here on C4, ebay, or in the USA.
See asking prices for up to and over $2,000 lately for C4 dana 44 & all hardware for a true bolt in swap.
Old 03-10-2011, 09:32 PM   #11
CF Senior Member
Broken spider gears?
get on C4 parts,
Dana 36's a give away there.
Free or up to $100.
You pay for shipping.
Old 03-10-2011, 09:33 PM   #12
westgl
Junior Member
Default This is a new rear end to me
I just bought this rear end from Ikerds.
i asked them to inspect and make sure to send me a good one, I thought they would send me a good used one, But the spiders are missing most of there teeth.
I thought i was getting a Dana 44 but they sent me a 36.
it is not exactly what I expected, i did not expect to have to rebuild it after paying so much for it.
westgl
Old 03-10-2011, 09:36 PM   #13
CF Senior Member
westgl
What did you pay for it?
Its a boat anchor with broken spider gears.
Should have been free to you.
Old 03-10-2011, 09:50 PM   #14
westgl
Junior Member
Default Bad Spider gears
I bought a complete rear suspension from Ikerds for $950.00 + $280.00 shipping.
I inspected all the control arms, rear spring, half shafts, rear brake disc's, calipers, and rear suspension Corner right & left.
I am building a project vehicle
westgl
Old 03-10-2011, 10:08 PM   #15
CF Senior Member
westgl
Call them back, Ikerd's.
Talk to the owner.
State the spider gears are in very bad condition.
Broken.
See what he can do to make it right with you.
You did not get a fair deal.
Unless you are happy with broken spider gears.
I would not be.
You and I are not dead yet.
Our country is not run by communists just yet.
We still have rights. lol
Brian
Old 03-11-2011, 07:27 AM   #16
WW7
CF Senior Member
WW7's Avatar
with Brian, you can't let them get away with something like that. Im sure if you call them and tell them whats going on they will take care of it for you. They probably just pulled the rear and sold it without opening it up for inspection.You also said you thought you would get a D44, not a D36. They may of screwed up and sent the wrong rear by accident.. You need to get this straightened out ....Call them!!!! WW
Old 03-11-2011, 11:06 AM   #17
westgl
Junior Member
Thanks Guy's,
I talked to Ikerd they said it should not have gone out that way.
But the funny thing is that (they shipped everything in separate boxes 5ea. to get under the shipping weight) the Pumpkin by it self, in it's own box separate from the batwing, it was Easy to look right in and see the damage, especially as Clean as it was.
Oh well Mistakes happen, at least they will make good on it.
Westgl
Old 03-11-2011, 12:20 PM   #18
aklim
CF Senior Member
aklim's Avatar
Send a message via Yahoo to aklim
I have broken too many 7.625 geared rear ends. One set of 4.10 gears broken, 1 set of 3.73 broken and one set of 3.73 where the pinion bearings spun on the rear end. In my Vette, within a few months, I found my 3.08 gears that were stock had a break when I was installing the D44.
aklim is offline   Reply With Quote
Reload this Page Dana 36 vs 44 Rear End
Tags
33, 36, 44, andd, c4, corvette, dana, difference, ends, gear, ikerds, oil, rear, rearend, rears, swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
