Are there any low profile Dist. for EFI small blocks?
Received 1,769 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I started some mock up of the new intake on my old engine before I pull it out. Its kind of a snug fit. Everything clears but the air filter barley touches the top of the hood.
Also, the air cleaner clears the distributor, but i done know if Il be able to get the wires on with the filter there. I am looking for a low profile, or even a small cap as a second choice, distributor that is also EFI compatible with the L98 computer.
The front mount is stupid expensive. Forgot about the L98 ESC. MSD might work if you ditch the vac and mechanical advance. Maby shoot them a email.
one of these help out?
http://store.knfilters.com/search/UnivOvalTap.aspx
I looked at so many filters. For the oval cone type filters, the smallest one with the proper size inlet for the LS throttle body is bigger than the round one I purchased. Its not as long, but the bottom flange is bigger so I would be pretty much in the same situation.
Im thinking maybe a small cap dist might provide enough clearance, but I dont know. Thoughts anyone?
I dunno if it'll work - but have you looked at the distributors that came stock on the 96-99 350 vortec (truck) engines? They are computer controlled, the cap is a 'flat' design that routes the plug wires nicely out each bank...
It's a thought at least - the clearance will be there - just have to check and see if you can adapt the wiring to the L98...
I did a quick search - here's a pic:
OH - the vortec uses an external ignition module and external coil - so you would need those two - I'd start by grabbing a wiring diagram for both and seeing if you can make heads or tails out of it... It'll be a custom wiring job for sure....
Also - I think a LONG time ago I saw a cap that was like that for the regular old HEI - you had to run an external coil for it - but that was probably 15+ years ago and can't recall seeing one recently...
Have you looked at this one? MSD 2340
You would have to run an external ignition box, but it looks low profile and has the "cam sync" output for EFI applications.
http://www.msdignition.com/Products/...stributor.aspx
WOW! I also just noticed the price on that one. I wont be able to afford that, not to mention all the other things I need to buy to make it work.
that pos distributor works with the accel dfi vii for sequential , rather than batch fire efi. I don't think it is short enough to solve the problem illustrated By the op.
Race on!!!
Jim
Race on!!!
Jim
Ive got another question. How much smaller is a small cap dizzy than the HEI one? Is it by any chance slightly shorter as well? Im only looking for like 1/4".
Wow, thanks! That is a pretty good difference, and probably enough to work. I think im going to go that route! I found an MSD at a good price.
Here's a picture of the hei with a remote coil.
