Removing Corvette Breadbox!!
Old 02-06-2011, 11:36 PM
86Vette350
86Vette350's Avatar
Default Removing Corvette Breadbox!!
Does any one know how to remove the breadbox that's on the passenger side on the dash? Going to do some custom work so I need to pointers on how to remove it out!! thanks!!
Old 02-07-2011, 12:06 AM
oldalaskaman
oldalaskaman's Avatar
you have to pull the dash pad, and theradio bezel.
Old 02-07-2011, 12:22 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Get the dash pad off!
Then you'll see the clips and have better access.
Old 02-07-2011, 12:31 AM
86Vette350
86Vette350's Avatar
is the box bolted in or screwed in? thanks
Old 02-07-2011, 12:33 AM
86Vette350
86Vette350's Avatar
o0 Pic looks great did you make that or order it from Ecklers? I saw they had a kit for 50 bucks but I can make one for about 10 dollars
Old 02-07-2011, 12:37 AM
oldalaskaman
you can make them, some times they make it to the parts for sale forum,
Old 02-07-2011, 02:40 AM
JrRifleCoach
Pop riveted and sheetmetal screws if memory serves correct.
It is NOT designed to be removed easily.
Old 02-07-2011, 06:46 AM
corvette95
corvette95's Avatar
Yeah, from what I remember the lower carpeted bolster has to come out and there are four nuts that are a royal PIA to get out, maybe someone can chime in on access to those nuts, the dash pad and radio are a breeze.
Old 02-07-2011, 07:08 AM
Pres712
Pres712's Avatar
Default Eckler's or Mid-America
If I remember correctly (I did this in '86) when I bought the kit from Eckler's it had instructions on "how to" included. It wasn't easy and took most of the afternoon.
Old 02-07-2011, 08:31 AM
AGENT 86
AGENT 86's Avatar
Made mine from 1/4" sheet ABS, less than $10 including paint.
Some info from my 86 FSM
http://members.shaw.ca/agent86/Dash%...%20Removal.pdf
Old 02-07-2011, 08:55 AM
LaVidaLoca
LaVidaLoca's Avatar
It has been years since I took mine out, but I recall removing the top pad and the carpet section under it.
There was one diagonal metal strap near the middle (I think) that was going to be so hard to get to that I used a cutoff wheel in a Dremel and cut it in half. It went in the trash anyway so why be gentle removing it??
I have made a couple of mods to the dash to make getting it apart easier. It is an absolutely terrible design.
Smoke92 (02-07-2024)
Old 02-07-2011, 08:56 AM
LaVidaLoca
LaVidaLoca's Avatar
@Agent 86 > nice job. looks great.
Old 02-07-2011, 08:59 AM
oldalaskaman
I'm making mine like that, many thanks for the pid
Old 02-07-2011, 11:49 AM
Aardwolf
Aardwolf's Avatar
You don't have to take anything apart to remove it. If you want to you can go through the fuse box opening with a hand held saw to get at the brackets. Saw through the bracket or the fastener to release the whole box. The whole thing can be removed to be replaced with a panel that way. Replacing the bread box was one of the first things I did, the flat panel looks much better to me.
Old 02-07-2011, 11:50 AM
Jimbo 89
Jimbo 89's Avatar
Old 02-07-2011, 12:24 PM
Bronze85
Bronze85's Avatar
Clean
Old 02-07-2011, 01:10 PM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Here is a write-up on how to remove the breadbox. Also, I have a custom made American black walnut replacement dash panel if you are interested.
File Type: pdf
64Scout (02-23-2020)
To Removing Corvette Breadbox!!
Old 02-08-2011, 11:31 PM
86Vette350
86Vette350's Avatar
Agent 86 where did you get the sheet of ABS at? thanks Looks real good!! goin to install a screen in mine, try that and see how it goes, flat panel touch screen
Old 02-08-2011, 11:33 PM
86Vette350
86Vette350's Avatar
pmihaltian how much ya wanting for the panel? and do you have all the hardware to go with it? thanks it you want text me a pic of it at 501-281-6976 or email one at blueford_99@yahoo.com thanks again for all the help!!
Old 02-09-2011, 02:42 AM
mgafun
mgafun's Avatar
I'll show these again. Formerly made in CA but no longer available.
rahsputyn (06-03-2021)
Quick Reply: Removing Corvette Breadbox!!
