Is 93 Vette trans direct replacement for 87
I came across a 93 Corvette local with 44,000 miles that is being parted out and was wondering if the automatic transmission in it would be a direct replacement for the 700R4 in my 87 Vette?
Is this trans still the 700R4 or was 93 when they switched designations over to the 4L60?
93cruiser
I am close enough I might be interested in it.
Remove the valve body, seperator plate, internal wiring harness, pressure switches and wiring case connector from the 87, and install it in the 93 trans.
Use the checkball arrangement from an 88 if you have a late 87 valve body.
Use the 86 check ball arrangement if you have the early style valve body.
1987 was a transitional year.
I am supposed to pick up the 93 trans this weekend, it is the 700R4/4L60 with the TV cable but is a 5 pin plug in instead of the 4 pin like mine, I have been told it is just a matter of pulling the pins and putting my original 4 pins into the 5 pin connector, is this correct?
Is it this simple or is there more to it?
Pete K would I still need to Remove the valve body, seperator plate, internal wiring harness, pressure switches and wiring case connector from the 87, and install it in the 93 trans. and Use the checkball arrangement from an 88 if you have a late 87 valve body. Use the 86 check ball arrangement if you have the early style valve body, or could I just bolt it in and use it as is without problems?
Thanks everyone for the help
