head gasket.....
Old 01-21-2011, 03:44 PM
tjbagz
tjbagz's Avatar
Default head gasket.....
does anyone know of a good thread with pics covering a head gasket replacement?
Old 01-21-2011, 04:40 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What engine???
I know I've seen pictures an procedures to get the intake off an L98,
From there the heads are pretty obvious.
LT1 is soo simple you don't need pictures
You will need the factory service manual for the torque sequence when you put them back on.
Old 01-21-2011, 05:45 PM
tjbagz
tjbagz's Avatar
L 98 engine, what other items should I tackle while doing gasket, please keep in mind my skill is limited, but I need to learn more and want some winter projects..
Old 01-21-2011, 06:15 PM
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
Black89Z51's Avatar
I just rebuilt my entire motor about a week ago. I took the heads to a machine shop and got the works done. New valve springs, keepers, retainers, valve seals (use the intake seal on both intake and exhaust), 3 angle valve job, valves lapped, and the heads were decked 0.010" to flatten them.
Other than that, it's basically just a remove and rebuild. Make sure the block sealing surface is smooth and ultra clean. It will not be smooth as glass, as the gasket needs something to stick to, or it will leak. Use acetone to clean the block sealing surface and the heads prior to setting the heads down.
Use new head bolts when you do the job. The Fel-Pro bolts already have the sealant applied to them.
Other than that, it's pretty straight forward. Take pics and post them if you have questions. Someone on here will see it and answer it.
If you don't have a factory service manual, definitely get one before you start.
Old 01-21-2011, 06:47 PM
tjbagz
tjbagz's Avatar
Where is good place to purchase factory service manual? Would Chiltons show same info?
Old 01-21-2011, 07:04 PM
l98tpi
Max G’s
l98tpi's Avatar
I got mine from Ecklers or Mid America. It will cost around $150 plus, but it is well worth it if you are going todo a lot of your own maintenance. These are service manuals for all the systems on the car.
Old 01-21-2011, 07:28 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Gene Culley, a forum vendor. Do a search. Great prices and great service.
Old 01-21-2011, 09:27 PM
CorvetteMike2024
Corvette Junkie
CorvetteMike2024's Avatar
Received 2,023 Likes on 839 Posts
http://forums.corvetteforum.com/c4-t...se-advise.html
To head gasket.....
Quick Reply: head gasket.....
