how about a Injector Christmas sale.
Old 12-09-2010, 04:28 PM
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
Default how about a Injector Christmas sale.
until Christmas all these injector sets will be on sale. Please pm or call to order. Merry Christmas and Happy Holidays to all the CF members and their families!!! Free Shipping
NEW SMP stainless 22's for the 86-91 L98 269.00 a set
NEW SMP polished stainless 22 86-91 l98 289.00 a set
New Bosch 3 24 85 and 92-96 lt1 289.00 a set
NEW Bosch 3 32 all modded lt1 and l98 289.00 a set
NEW Bosch 3 36 " 329.00 a set
NEW Bosch 3 42 " 349.00 a set
Rebuilt Bosch 3 22 including gasket and rail seal kit 179.00
Rebuilt Bosch 3 24 " 199.00
Rebuilt Bosch 3 22 injectors only 148.00
Rebuilt Bosch 3 24 injectors only 169.00
All rebuilt sets have a 3 yr warranty and are flow matched.
INJECTOR SERVICE
SET OF 8 ULTRASONIC CLEANING, FLOW TEST BEFORE AND AFTER, COIL CHECK. REPLACE FILTERS O RINGS AND PINTAL CAPS 89.95
Old 12-09-2010, 06:51 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What would I need for a mild 383 LT1 - I've been told it makes in the 400 fwhp?
Old 12-09-2010, 09:30 PM
FICINJECTORS
Supporting Vendor
you need a 32lb injector and 43.5psi fuel pressure.
Old 12-09-2010, 10:51 PM
Matatk
Matatk's Avatar
How about an injector cleaning sale
Old 12-09-2010, 11:55 PM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
My 383 runs pig rich on the 22 pounders. how much worse would it be with 32 pounders???
Old 12-09-2010, 11:57 PM
FICINJECTORS
Supporting Vendor
Originally Posted by matatk
how about an injector cleaning sale :d
check the list on the sale just added service special
Old 12-10-2010, 12:00 AM
FICINJECTORS
Supporting Vendor
Originally Posted by coupeguy2001
my 383 runs pig rich on the 22 pounders. How much worse would it be with 32 pounders???
there is no way it should.. 22 lb only supports a stock l98.. Stroker with mods should be lean on 22.. What are the other symtoms, you can put 36's in a stroker as long as the ecu is tuned.
Old 12-10-2010, 08:43 AM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
You've got an exhaust or vaccum leak.
I have the same issue on my 92 and I can hear the exhaust leak.
I've been running Jon's rebuilt injectors for almost 3 years now and have been 110% satisfied.
I'll be calling him today to order the ones for my 383.
Old 12-10-2010, 01:55 PM
aklim
aklim's Avatar
Received 2,225 Likes on 1,939 Posts
Jon's did some good work for me recently. Without services like cleaning, I'd be doing nothing but replacing injectors. Sure, I could waste money on a can of snake oil but it wouldn't have found that I had a flow problem in one of my injectors nor would it have fixed the collapsed filter.
Old 12-12-2010, 09:37 AM
corvette95
corvette95's Avatar
If I send you 16 stock Multec injectors from my ncrs 89, think you could get me at least EIGHT good cleaned and checked injectors from the bunch? I know at least a couple of them are malfunctioning when hot.
corvette95@charter.net
Old 12-12-2010, 09:57 AM
FICINJECTORS
Supporting Vendor
I can, plus I have about 1000+ cores here also. I cannot guaranty how long they will last but for NCRS we have no choice.
Old 12-14-2010, 12:10 PM
FICINJECTORS
Supporting Vendor
ttt
Old 12-14-2010, 08:23 PM
eaglevision993
eaglevision993's Avatar
Hm, I was thinking about an injector swap recently as mines are still original. I have a mostly stock 88 L98. I assume I need 21 or 22" injectors right?
Old 12-14-2010, 09:30 PM
FICINJECTORS
Supporting Vendor
22 is stock
Old 12-14-2010, 10:02 PM
87 vette 81 big girl
87 vette 81 big girl's Avatar
Originally Posted by FICINJECTORS
22 is stock
Are You working on a New and Improved Bosch 3 Fuel Injector Jon?
For the 1986-1991 L-98 Corvettes? A Bosch 3 rated at 22.9 lbs per hour?
Had a PM sent to by a fellow forum member saying that you are working on such an injector.
Still in the development stages ? Or have you tested them in a L-98 Corvette?
Using your BOSCH 3's since spring of 2008 in my 87 Vert.
Work great.
Worked ok at 34 PSI with vacuum line off FP regulator. Stock fuel Pressure. BLM's of 140 - 150.
Raised Fuel pressure up to 57 PSI, vacuum line off of regulator, with aftermarket regulator. BLM's of 128 - 130. Perfect.
My vette runs like an animal all times now.
Pulls hard to 150 MPH +.
Blows Rear Tires off the line from a stop nailing gas, no powerbraking.
Car Hooks up 20 to 50 feet later.
P315-35ZR17 rear tires, 11X17 inch rear rims.
Stock E- Prom.
Ran against a buddies HEMI late Model Charger about a month ago.
My Vette performed Very well against him. He was amazed. LOL
Those Hemis are fast too.
Understand there is an Offset difference with BOSCH 3's compared to stock BOSCH 1's origanaly used in 1985-1988 TPI Vettes, Correct?
What is exactly the offset difference Number?
Purchasing a MOATES PRAGRAMMER THIS WINTER AFTER THE HOLIDAYS TO DO MY OWN ECM PROGRAMMING. TUNE FOR MORE PERFORMANCE. AND FOR 410 CI ENGINE SWAP LATER IN 2011.
Thanks Jon, BR
Old 12-14-2010, 11:14 PM
FICINJECTORS
Supporting Vendor
Work great.
Stock E- Prom.
Thanks Jon, BR
i have the 22.9 all tested and ready to go.. problem is they are used on BMW euro models. waiting for cores to get through customs. They have been in Miami for weeks. I also machined new discharge plates for the fords and they work perfect also. Only problem is these will be priced 50 higher than the current 22 but, still a bargin at 219 a set. The Euro Bosch are black and have a clip spot even though its not used and the others will be available in yellow or white. I will add them to the site as soon as we have enough inventory. I do have about 10 sets of each now so if you are interested just pm me
Old 12-15-2010, 09:30 AM
eaglevision993
So I guess I should go with a set of Bosch III reman 22"s.
Could you send me a PM with the shipping charges to Germany?
Best regards
To how about a Injector Christmas sale.
Old 12-15-2010, 10:01 AM
89vette
89vette's Avatar
What do you mean by all modded on the 32 lb L98 Injectors?
Old 12-15-2010, 10:21 AM
FICINJECTORS
Supporting Vendor
when we rebuild them we change the difuser plate on the bottom to change and match the deired flow rate.. Thats only on the rebuilts, the new ones have that done at the factory
Old 12-15-2010, 10:28 AM
Alan777
Alan777's Avatar
hey I'm getting a 383 L98 built, probably gonna end up running 350-400whp with a miniram.
Can you recommend the best injector for that setup, or do you need more specifics? The engine shop wants me to get the injectors when i bring the motor in.
Quick Reply: how about a Injector Christmas sale.
