Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-08-2002, 10:48 AM   #1
Valleybacker
Sic semper tyrannis
Support Corvetteforum!
Valleybacker's Avatar
Default How do I set the Clock time, and change radio stations....?
On my 92.
Whats the procedure for setting the clock time.
Whats the procedure for programing stations for the (1,2,3,4,5,6) slots?
What does Cr02 mean?
What is SVC?
I haven't got my manual yet, so I would like to know what these things do.
Valleybacker is offline   Reply With Quote
Old 04-08-2002, 11:05 AM   #2
Springer's LT4
CF Senior Member
Cruise-In III Veteran
Springer's LT4's Avatar
Send a message via ICQ to Springer's LT4
Default Re: How do I set the Clock time, and change radio stations....? (Marty McFly)
To set the clock, turn the radio off and press the SET button, then use the up and down tuner hours to adjust the time.
For radio stations, turn the radio on, go to the station you want, press SET and hit one of the 1 thru 6 buttons.
Cr02 is used for certain type of tapes...
Not sure what SVC is.. I think it means your picking up a good signal.
Springer's LT4 is offline   Reply With Quote
Old 04-08-2002, 11:33 AM   #3
Valleybacker
Sic semper tyrannis
Default Re: How do I set the Clock time, and change radio stations....? (Springer's 95)
I think SVC is the thing that increases music volume with speed.
If I turn it to "L" or "off" It won't increase volume as much..
Anyone know anything about this?
Old 04-08-2002, 11:33 AM   #4
Valleybacker
Sic semper tyrannis
So many new buttons... :crazy: :crazy:
Old 04-08-2002, 11:44 AM   #5
vetluvr
CF Senior Member
St. Jude Donor '08
vetluvr's Avatar
CR02 = Chrome cassette tape. If a cassette tape has CR02 on it then use this setting.
SCV = Speed control volume. Set the volume when you are at speed, and it will automatically change the volume when you slow down (stopping at a light).
Push button and it will change in succession "Off, High, Medium, Low".
vetluvr is offline   Reply With Quote
Old 04-08-2002, 11:59 AM   #6
Valleybacker
Sic semper tyrannis
Default Re: How do I set the Clock time, and change radio stations....? (vetluvr)
lol, my friend and I were like "whats Dichromium oxide" mean... :lol: :lol:
Old 04-08-2002, 12:57 PM   #7
mxw128
CF Senior Member
mxw128's Avatar
SVC controls the volume as you increase and decrease speed (makes it louder the faster you go and quieter the slower you go) On a 96, there is an adjustment ring ont he volume **** that allows you to select "H" (for High), "L" (for Low) and Off. The High setting gets louder, quicker than the low setting. I don't know if other years control this feature differently.
Mike
96 CE - Stock (yeah, yeah..no pics or fancy sig..... yet.... ) :jester
mxw128 is offline   Reply With Quote
Old 04-08-2002, 01:12 PM   #8
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: How do I set the Clock time, and change radio stations....? (mxw128)
The SVC works the same on the 92 as your 96. It is good for the convertable. Set it to high for top down, low for open windows, and off for closed up. It is actually the only feature I miss from the bose system. The CrO2 was the Cromium tapes from the early to mid 80s. Pretty much died out about 15 years ago. Most later decks automatically engaged the type of tape with the correct noise reduction and tape type.
92TripleBlack is offline   Reply With Quote
Reload this Page How do I set the Clock time, and change radio stations....?
Tags
1984, 1994, 1996, adjust, change, clock, corvette, cro2, programing, radio, set, setting, station, stations, timer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
things to look for when buying a c4 lange C4 General Discussion 19 08-06-2005 01:29 PM
Launching a Z06 for drag racing oderja C5 Z06 Discussion 14 03-19-2003 10:19 PM
My experiences with drag racing my Z06... Going from 12.7 to 11.933 J-Rod C5 Z06 Discussion 32 11-03-2002 12:36 AM
"how-to-install" hydrobooster dial-up beware 71'AirStrike C3 Tech/Performance 22 09-24-2002 03:54 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
