Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-11-2010, 12:53 PM   #1
Phuncky Feel One
Junior Member
Phuncky Feel One's Avatar
Default C4 Wiper Blades
Ok guys, I know wiper blades aren't up there when it comes to working on your car. I hope to save a newbie some time when looking to replace their wiper blades on their C4 without the BS run around. As you know, third time's a charm usually. The first and second time a PepBoys employee gave me their stock wiper blades for my C4 which would hit the hood when wipping (RainX newest blade & Anco). Returned them and went to Advance Auto Parts and their employee gave me the RainX weatherbeater wiper blades (blades themselves were very low profile). I dremeled the plastic clip holding them to the arm even with the blade itself. Now the wipers work 100% better than the stock ones I threw out.
20" Rain Weather Beater wiper blades $11.99 ea at Advance Auto Parts
Phuncky Feel One is offline   Reply With Quote
Old 12-11-2010, 12:55 PM   #2
jhammons01
CF Senior Member
jhammons01's Avatar
There is a brand called "Exact fit".....get them at Kragen (now O'reilly's)
It will cure your problem and yes they fit just fine under the hood
jhammons01 is offline   Reply With Quote
Old 12-11-2010, 02:19 PM   #3
383vett
CF Senior Member
383vett's Avatar
Simpler solution for my bracket car...no wipers.
383vett is offline   Reply With Quote
Old 12-11-2010, 02:43 PM   #4
overdrawn
CF Senior Member
overdrawn's Avatar
Wanna hear something funny, I have never turned mine on, don't even know if they work.....
overdrawn is offline   Reply With Quote
Old 12-11-2010, 02:46 PM   #5
383vett
CF Senior Member
383vett's Avatar
Quote:
Vettes aren't supposed to be out in the rain.
Old 12-11-2010, 02:58 PM   #6
mcm95403
CF Senior Member
Support Corvetteforum!
mcm95403's Avatar
Send a message via Yahoo to mcm95403
Since someone else brought up the subject of wipers.........
My drivers side wiper travels so far to the left side that it goes up and over the A-pillar and is taking the black coating off the window trim. About half of the wiper blade is moving off the glass. Is this one of those common 84 problems that was corrected in later years? If so, I'd certainly like to get that fixed since my Vette is an all-weather fighter
__________________
www.dunritenetworks.com
previous Vettes: 84 CFI auto, 99 Nassau Blue 6-speed
current Vette is a Turquoise Metallic 91 automatic, 3.07's, Fast Burn heads, SD LT-4 cam, Bosch III's, Accel Super Ram & 58MM TB, LT-1 manifolds, Magnflow catted Y, Flowmaster direct replacement mufflers, 1984 Z51 springs, Koni's, C5 brakes, 275's/315's, VB&P 32mm front sway bar
mcm95403 is offline   Reply With Quote
Old 12-11-2010, 03:02 PM   #7
92WhiteVetteGuy
CF Senior Member
Quote:
Hi,
Keep your old wiper arms and pick-up some ANCO Wiper Refills U-20R for ~$5. You can find these at any independent auto parts store. Retailers like Walmart and the auto chains carry only replacement wiper arms/assemblies. The aftermarket arms don't clear the hood.
__________________
92WhiteVetteGuy
92WhiteVetteGuy is offline   Reply With Quote
Old 12-11-2010, 03:03 PM   #8
sailorsteve
CF Senior Member
This is adjustable, refer to your FSM.
sailorsteve is offline   Reply With Quote
Old 12-11-2010, 03:26 PM   #9
383vett
CF Senior Member
383vett's Avatar
I always thought the fiberglass resin Vettes are made of dissolve in the rain.
Old 12-12-2010, 06:27 AM   #10
HlhnEast
CF Senior Member
HlhnEast's Avatar
Marc, I think there are adjustments but kinda sounds like either your blade assembly is not sitting right on the pivot or your linkages under the cowl are worn out and sloppy. You might try marking the arm assembly and a reference point on the cowl with a fine point and rotate it clockwise a spline or two. The assembly has a clip at the pivot that needs to be slid a little and then pry gently to pop it off. If it aint too corroded it may come off pretty easy. If not a straight claw hammer under the assembly at the pivot generally works. Be careful with it.
Good luck!
HlhnEast is offline   Reply With Quote
Old 12-12-2010, 08:22 AM   #11
larry93lt1
CF Senior Member
larry93lt1's Avatar
Location: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Only the '83's were made of the water soluble resin that's why they are so hard to find.
larry93lt1 is offline   Reply With Quote
Old 12-12-2010, 08:28 AM   #12
mseven
CF Senior Member
mseven's Avatar
mine will melt ..or so I'm told, wasn't that an option in 90?
The only time I even tried mine is when I bought the car in 04. I'm with the wiper delete plan and some rain x on the glass, however keeping the arms on the car makes it street legal in MI.
mseven is offline   Reply With Quote
Old 12-12-2010, 10:09 AM   #13
sailorsteve
CF Senior Member
Quote:
Good luck!
I don't know if the arms are the same for all C4's, but on my car they only go on one way, so you can't move them to a different location like you could on older cars.
Old 12-12-2010, 10:19 AM   #14
Geardo
CF Senior Member
Geardo's Avatar
They tried to sell me some fancy blades at Autozone, told them they wouldn't fit on the Vette, bought some RainX, they fit and work great, no mods needed.
Geardo is offline   Reply With Quote
Reload this Page C4 Wiper Blades
Tags
1994, anco, blade, blades, c4, change, corvette, corvetteforum, low, profile, remove, size, travels, wiper, wiperblades
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
