Serpentine Belt - Which Way? '93-LT1
Which way do the teeth go?
Do the teeth go into the:
Crank, Alternator, Air Compressor
or
Tensioner, Power Steering, Idler Pully?
Ethier way you do this something is going to be chewing on the flat side of the belt.
Thanks,
Larry...
or
Thanks,
Larry...
Yep start at the teeth on the crank, then work your way as according to the diagram. Some pulleys will contact the flat side. I don't know about the dual sided belt that mashinter is talking about above since I have a 94.
There is a belt routing diagram under the hood and I think it's on the upper radiator shroud. By starting with the ribs facing on the inside of the belt loop, place the ribs on the crank pulley and follow the diagram.
