Belt tensioner broke.... Need help???
I went for a test ride tonight and was not even getting on it very hard and WHAM!!!!!!!!! WTF is wrong and waht is all that noise... I thought my new exhaust work came undone.... I stopped and the belt was on, but was kind of just hanging on.....I limped her home and found that the belt tensioner had broke....Well the little tit that goes into the grove where it bolts up...What would have caused this??? How much and where can I get one from tomorrow?
Thanks.... :eek: :eek: :eek: :mad
Re: Belt tensioner broke.... Need help??? (apollo30346)
Most parts stores sell the pulley but not the tensioner :( . You could try a shorter belt if you have to drive.
Re: Belt tensioner broke.... Need help??? (Bluevette85)
You have got to be joking....I have got to get this done today....I just have to find where to get it from....
Will one from any 350 cid work, like from a camaro, or does it have to be for the vette?
Thanks for the replies...
This is the first time that I have heard of one being broken. I have many times replaced bad bearings in the tensioner. But never have I heard of a broken casting. Most parts stores usually sell the pulley with the bearing already pressed in to it. But I would guess that you would have to either go to a dealer or a junk yard to buy the whole assembly. I am not sure if they interchange between different years. But some F bodied GM cars use the same tensioners. I would take your part with you and compare it.
Good Luck! :chevy
Good Luck! :chevy
Re: Belt tensioner broke.... Need help??? (Sharky Guam)
I think I broke it last week when I was removing all the smog junk... and I went to remove the belt and I think I pryed it the wrong way first and I thought I heard something that did not sound right.... I stopped and looked, but did not see anything wrong and I must have pryed the correct way and the belt came off.. Funny thing is when I put the car back together I went for a test ride and all was fine and I drove it to work yesterday and was fine. But, I wanted to take a ride last night with the top off... I must have had the bolt tight enough that it did not slip until then... Good thing I was right down the street.... I think it's time to sell...... :eek: :eek:
I just bought one at the last detail in Georgia They might be able to over night it to you. Also Ecklers is in Fla. Probably not any where near you though,hope this helps.
Re: Belt tensioner broke.... Need help??? (Rick92)
your not supposed to pry the belts.... thats a no no.... :nono: But I never heard of one breaking either, hope you have some luck finding one
Re: Belt tensioner broke.... Need help??? (StealDads67)
just for reference..i paid about 95 dollars for a whole assembly from the dealer ship. Takes five minutes to change out. Be sure to align the little marker in the right position and thats all there is to it.
Re: Belt tensioner broke.... Need help??? (Oh My)
Good news....I got one today from the dealer...$96.00 tax and all....took 10 mins, and she was running great....
Thanks to all for the help.....
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
How do you take the tensioner off?
I picked up a new belt tensioner at the Chevy dealership also for about $80.00. It's different from the original one is. It has a plastic pulley instead of metal. :rolleyes:
Re: Belt tensioner broke.... Need help??? (The^Nomad)
Yep, thats the same one I got, but had to pay $96.00......No fair you got it for $80.00.... :D :D
Re: Belt tensioner broke.... Need help??? (vettes rule)
