Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2010, 12:09 PM   #1
LBYRNES
CF Senior Member
Support Corvetteforum!
LBYRNES's Avatar
Default Optispark replacement - '93 LT-1
I had to replace the water pump in my '93 LT-1. Usually, a leaky water pump kills the Optispark so I was going to replace it with a new MSD Opti. However, the FSM says that I need to remove the balancer and hub. That requires me to lift the engine. I don't have the equipment to do that, so the question is:
Can I replace the Optispark without pulling the balancer and hub?
Thanks,
Larry...
LBYRNES is offline   Reply With Quote
Old 12-10-2010, 12:27 PM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
You'll need to pull the balancer, not th hub. Also, you don't have to lift the engine to pull either.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 12-10-2010, 12:32 PM   #3
jaa1992
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
You just need to pull the ballancer off.
Mark the hub and balancer, remove the three bolts.
From underneath with a blck of wood on the balancer whack it a few times.
Using the hub bolt rotate the crank 90*, whack again, repeat until the balancer comes off.
Clean the balancer and hub, put a little anti-sieze on the mating surfaces when you put it back on.
It is CRITICAL that the filled tooth on the opti matches the gap on the spline when you replace it. The opti should "pop" on and the bolts just hold it in place. DO NOT use the bolts to draw the opti on!
Where in Atlanta are you? I may have some time next Sat if you want some help.
jaa1992 is offline   Reply With Quote
Old 12-10-2010, 05:26 PM   #4
LT1*C4
CF Senior Member
LT1*C4's Avatar
As others have mentioned, all you have to do is remove the ballancer in order to have enough clearance to slide out the optispark. You do NOT have to remove the engine.
I did a write-up about my recent optispark swap a few month's back on my '92 'Vette. It might come in handy for you, should you choose to do the swap yourself. Just follow the link in my signature. Hope that helps.
As for the MSD opti, the jury's still out on their long term reliability since there have been a lot of complaints of them failing after a few month's of use and even a few showing up D.O.A. Right inside the box.
Maybe it was just production issues on MSD's first few batch's of optisparks, but there have been numerous unhappy MSD owners...
I just purchased a GM factory replacement (not a cheap chinese-made ebay knock-off) when I replaced mine. I figured what the hell, the original lasted 17 years, so they can't be all that bad
It's the cheap ones that are causing everyone problems...
LT1*C4 is offline   Reply With Quote
Old 12-10-2010, 07:53 PM   #5
pcolt94
CF Senior Member
pcolt94's Avatar
Another consideration
The other side of the coin is if it is running really good and your happy, leave it alone till a problem develops. A lot of people have gone back to the original GM opti after having problems with other systems and optis.
It's your call and definitely a judgment thing, no right or wrong answer. Mileage is a factor but not a definite determination. Neither answer is a sure thing. Depends how much you want to play with the car now or later.
If you decide to do it now, there is definitely lots of help from the Forum.
pcolt94 is offline   Reply With Quote
Old 12-10-2010, 09:26 PM   #6
airplane50
CF Member
airplane50's Avatar
Have an MSD opti with 8,000 miles and 2 years on my '94. Replaced a GM opti installed by a Chevy dealer that lasted 4,000 miles. Original opti went at 44,000. Both failed because the water pump seal leaked. The MSD is vented which is a nice feature.
airplane50 is offline   Reply With Quote
Old 12-11-2010, 10:41 AM   #7
LBYRNES
CF Senior Member
LBYRNES's Avatar
Everyone, THANK YOU!
As so many of you pointed out, the engine did not need to be lifted. The balancer came off with no trouble. I was so relieved by your answers that I went directly to the garage and worked until it was time to retire for the evening. I forgot to post this thank you before I started. As of this moment all I have to do is put the water pump back in. Everything else is done.
I used the MSD because (a) I paid $499 for it already, (b) the stock opti had gotten very wet.
Anyway, thanks everyone.
Larry...
Old 12-11-2010, 01:08 PM   #8
surfer93
CF Senior Member
surfer93's Avatar
Put a $1 piece of hose over the weephole and you would not be needing this help.
Just get some high temp adhesive and glue a hose to the weep hole and you need not was $500 again.
This is in Tech Tips, which I guess I am the only one who reads it.
surfer93 is offline   Reply With Quote
Old 12-11-2010, 01:10 PM   #9
surfer93
CF Senior Member
surfer93's Avatar
Also, put sealant all around the opti and that will save your opti. Just don't drop the WP on the opti , that will ruin your day and your pocketbook.
Old 12-11-2010, 02:08 PM   #10
rinosaur
CF Senior Member
rinosaur's Avatar
Is it the WP shaft or front plate (weephole) that usually leaks?
rinosaur is offline   Reply With Quote
Old 12-11-2010, 03:09 PM   #11
sailorsteve
CF Senior Member
Quote:
It's the weep hole. If it leaks, you will weep, too.
sailorsteve is offline   Reply With Quote
Old 12-23-2010, 03:12 PM   #12
0ChandlerMotorsports
Former Vendor
Send a message via ICQ to ChandlerMotorsports Send a message via AIM to ChandlerMotorsports Send a message via MSN to ChandlerMotorsports
If you haven't bought already we've got a unit with a better rep than MSD's for $114.99
ChandlerMotorsports is offline   Reply With Quote
Old 12-23-2010, 03:25 PM   #13
syco_cop
CF Senior Member
Quote:
In what country are the parts made and the unit assembled?
syco_cop is offline   Reply With Quote
Old 12-23-2010, 07:44 PM   #14
SJW
CF Senior Member
Location: '94 Ragtop 6-speed & LT4 Coupe, Central Maryland
Details?
TIA,
Live well,
SJW
SJW is offline   Reply With Quote
Old 03-06-2011, 12:41 PM   #15
sl21
Junior Member
I have had many problems with the optispark and have had to buy about 6. I would like to add that in addition to all the other problems given, there is often a problem with the coolant bleeder screws being left open. I last had my 93 distributor repaired at the dealer. About a year later I noticed a small coolant leak where the screw had not been tightened quite enough.Might want to check this as I think it is the source of many problems and not just the optispark getting water in it.
sl21 is offline   Reply With Quote
Old 03-27-2011, 03:55 PM   #16
Flyinrio
Junior Member
Default Balancer position
Hi , Just changed the Optispark unit and realized I did not mark the position the balancer was when I removed it. Which position is the arrow on the pulley supposed to be ?
Flyinrio is offline   Reply With Quote
Old 03-27-2011, 04:25 PM   #17
STL94LT1
CF Senior Member
STL94LT1's Avatar
It only goes back on one way, the holes are slightly offset.
__________________
2006 Cobalt LS (DD)
Old 03-28-2011, 09:53 AM   #18
Flyinrio
Junior Member
Default Balancer
Thanks for the reply. I did get it back on the way I believe it came off and it went right on. I assume after reading your post I have it on correctly.
Thank you!!
Old 03-28-2011, 05:39 PM   #19
tblt44
CF Senior Member
tblt44's Avatar
Quote:
It will only bolt on one way,the bolts are not equally spaced
tblt44 is offline   Reply With Quote
Reload this Page Optispark replacement - '93 LT-1
Tags
1994, 93, balancer, c4, corvette, lt, lt1, optispark, problems, removal, removing, replace, replacement, swap, wet
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
