How about this valve trane noise? Would you call it normal?
Old 12-09-2010, 11:38 PM
  #41
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Originally Posted by korvette4u
ok. .040" cold? the spec on #155 binding occcurs at .520, that makes .024" too much lift: Nominal Open Pressure & Height should not be exceded.. spec i found are here: check spring specs here,,,BTW just trying to help up to you now..
You must not know what quench is. To be honest, I shouldn't have entered that (irrelevant) spec here.
IIRC, the AFR spring upgrade package is "good" to .600" lift.
Old 12-10-2010, 04:43 AM
  #42
korvette4u
korvette4u's Avatar
ooohhh ahhhhh gigle,,wow---greeg you should have bought the patriot 220's no upgrade needed.. but of course, you knew that!!
so tell us why do you have valve train noise problem? good luck
irrelevant spec are as :they have c-5 and c-6 now no retro fits needed.. these work right out the show room
Old 12-10-2010, 08:16 AM
  #43
GREGGPENN
GREGGPENN's Avatar
Patriot's and C5's....interesting attempt at a reply.
Isn't this where I should say: "Well there's another country heard from!"
BTW: In case you THINK you figured out something I don't know, look at AFR's spring page here. I'm running their 8019 set that's good to .650" lift.
Old 12-10-2010, 11:40 PM
  #44
korvette4u
korvette4u's Avatar
thats nice ..i'm so impressed..truly YOU see that i CARE!!!
Old 12-11-2010, 12:14 AM
  #45
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
Is it possible that your retainers are hitting the underside of the rockers on the OD of the retainers?
Old 12-12-2010, 12:49 PM
  #46
DarkBlue88
DarkBlue88's Avatar
Location: Charlotte NC, behind someone going 10 under the speed limit
Greg here's a vid of my homebuilt EFI setup and top end changes, before tune. It has AFR/TPiS heads and a 228/228 flat tappet cam with Comp Ultra Pro Magnums with .528 lift(1.6). It's quiet cold, but gets like this hot. Hasn't gotten any worse, adjusted them 3/4 turn down. They're also stock 305 valve covers, and very thin steel.
Old 12-12-2010, 02:46 PM
  #47
JAKE
JAKE's Avatar
Originally Posted by mtwoolford
Is there a consensus of opinion here? Is it 1/4 turn ? 3/8 turn ? 1/2 turn ? 3/4 turn?
Lets hear from an expert who thinks WAY outside the box.
Tuned Port Induction Specialties (TPIS) "The Shape Of Things To Come" in their publication LT-1 HINTS & L-98 UPDATE, at page 9:
"Effect of valve lash on hydraulic camshafts"
" One of the lessons learned (competing in the 1994 and 1995 World Challenge Series) is that to achieve elevated RPM's out of these camshafts (all hydraulic camshafts - flat or roller tappet) is that you need to preload the lash at least two turns below zero and sometimes more....
....Three turns below zero is extreme for the street but two turns is not out of the question. UNDER NO CIRCUMSTANCES SET THEM AT ONE TURN OR LESS" (emphasis added). "
Any thoughts ?
Many months ago I called TPiS about that setting recommendation. I called right after I read it and was told it's only to be used for racing.
If you'd like you can call them too, to see if anything's changed on that. As I wrote, it as many months ago (although it was this year) that I called.
Jake
Old 12-12-2010, 02:51 PM
  #48
JAKE
JAKE's Avatar
Originally Posted by WW7
I have never heard of or known anyone to set the preload at more then one full turn past 0 lash.. The FSM for my 89 says 1 full turn. I don't know if this above statement would be something to try without a little more investigation.. You could do some serious damage if wrong...Also if 1 turn is suppose to put the plunger half way down, wouldn't 2 full turns bottom the plunger out??..God only knows what 3 turns would do...WW
The FSM for the 96 LT1 specifies one full turn +/- 1/4 turn, which would mean One and One Quarter Turns would still be within spec.
GM loves to change things.
Jake
Old 12-12-2010, 02:58 PM
  #49
STL94LT1
STL94LT1's Avatar
Any thoughts ?
You know it's funny, for years I have read on the 'net that very little preload after zero lash will extend the rpm range.
Old 12-14-2010, 10:31 AM
  #50
BadSS
BadSS's Avatar
seems the 155#@ 1.800 is closed installed lbs/ hieght, and the compressed open height 352#@ 1.280 a difference of .520 " is your problem.. not by much ! only .068" too much to function without binding.. may need to change springs! maybe use 185#, these are good to .650"
hope this helps
Yep that helps more than you know. The installed height and coil bind height is the same for both the 155# and 185# springs you linked.
Old 12-14-2010, 03:33 PM
  #51
THE 383 admiral
THE 383 admiral's Avatar
if he has the Comp Cam pro true roller rockers as mentioned!! that should not be a ISSUE...
I was thinking of them hitting.. but I have the same type rockers and larger springs.. they would on most aluminum rockers
But you should Always Know or check!!!!
Old 12-14-2010, 10:05 PM
  #52
GREGGPENN
GREGGPENN's Avatar
You're right, that's not the problem. I'll try adding more preload when it gets warmer. I'll also replace the DS header gasket to eliminate my pin-hole leak. Then, we'll see where it's at. If it's still similar, I'll go with STL94LT1 and assume the CC ProMags are just noisy. Of course, I'll consider that Cam profile could be a factor as well. (It's certainly alot more aggressive than stock!)
But then again...so is the car when I mash on the go pedal!
Old 12-15-2010, 03:58 PM
  #53
GREGGPENN
GREGGPENN's Avatar
I posted feedback from TPiS on page 2 of this thread. Because I also had been pondering over the crank-it-down vs leave it loose paradox, I emailed Clay again. Here is his response....
On Wed, Dec 15, 2010 at 12:34 PM, Clay to Gregg....
We dont actually recommend that, it was a observation that we learned on the dyno, it is merely information. We did it when we ran World Challenge in the mid 90s. It is NOT something that I do on engines that I build. And as far as pumping up if you take up the space in the lifter by cranking it down nealry bottoming it out there is very little space for oil.. it cant pump up.
On Wed, Dec 15, 2010 at 12:16 PM, Gregg to Clay.....
Clay, why does TPiS recommending cranking lifters down vs the “conventional” ¼ turn to avoid float? Is your goal to maximize lift, flow, and power – while hoping the valves don’t float? Does the extra-tight adjustment somehow prohibit lifters from pumping up where they’d cause valve float?
Hope this clears it up for everyone. Bottom line: Don't do the 2-3 turn modification unless you're looking to convert your hydraulic to a psuedo-solid lifter cam setup -- under race conditions, with a white elephant charging toward you...during a solar eclipse.
Quick Reply: How about this valve trane noise? Would you call it normal?
