Rack &n Pinon hose position
I think I have the low and hi pressure side hooked up wrong, (reserved). I am trying to get my 63 vette rod running, I have a 94 R&P with a vintage air front runner. Pictures on the hose hook up would be GREAT.
Here is the way I have have hooked up.
Lower connection of the R&P goes to the upper position of the reservior tank
Lower position of reservior tank goes to the lower connection of the PS Pump
Upper connection of the PS Pump goes to top connection of the R&P
Confusing UH?
George
Confusing UH?
George
The return goes through the cooler and has a low pressure hose back to the reservoir. This would be the top hole on the rack. THe forwardmost hole is the pressure port from the pump.
