sys flashing in dash
Recently I had my break booster replaced at a local chain repair shop. I returned to pick up my car, they battery was dead and would not start. I then promtly walked back inside to imform them they need to figure it out, quickly. Found they did not adjust the break light switch at the break peddle. The lights just stayed ON. Ya think you may have noticed that little bright row of lights at the back end of the car....
Anyway, after charging of my battery and driving for nearly 2 weeks, i still have the "sys" light in the dash also my fuel guage shows empty. I have tried the search on here as i do on a regular basis, it is a corvette. I have not found anyone with the same fuel guage issue associated with the sys light. looking forward to any help. thanks in advance.
With the "sys" light flashing, there is a code stored in the ccm. That code might be of some help in diagnosis. Look in the forum "search" function for info on reading ccm (not ecm) codes, I believe your year self-diagnoses.
I've had my SYS flashing for month but everything works and no codes are stored (96 LT4). I read somewhere that replacing factory stereo will do that. Just in case youve done anything else like changing stereo.
found the main problem, battery is less than a year old. when then brake booster was operated on, the pedal switch was imporperly adjusted causing the brake lights to stay on. the ccm code was stored as a weak battery. cleared the code and will now move on with diagnosis of fuel level issues. thank you to all with usefull advise, unlike blondes with large mamories beleiving that they really brains, when infact, they're just a mound of fat with a nipple.
my 90 has a sys flashing on dash
my 90 has sys flashing on dash too . battery was also low , have charged it now how do I clear the ccm code ?
If you need to just start a "NEW THREAD"!
