How do you remove window tint? I cant pass inspection!!
Im down here in North Carolina now and I have to get a NC safety inspection before I can get a base sticker and the damn tint on my car is too dark the side windows are 27% and the back is 18% so I need to remove it.
Is there a trick besides just scraping it off with a razor blade?
Id like to save my rear defroster and not damage it!!
jp
jp
Re: How do you remove window tint? I cant pass inspection!! (phrogs)
For the front, take a water squirt bottle, mix a few drops of dawn detergent with warm water, work the tint/glue off with the razor knife. For the back, the same thing, but be real careful near the defroster wires. It might be safer to remove the hatch glass and set it on a work surface so you can control the razor with comfort.
Use lots of soap water.
Re: How do you remove window tint? I cant pass inspection!! (BBA)
i would not take a blade to that back glass. the film should peal off leaving the glue. simple green will sometimes work on breaking down the adhesive. scrub the glue off with steel wool. if the film flakes and wont come off in on big sheet, there is another method you will have use. let me know and i will explain.
Re: How do you remove window tint? I cant pass inspection!! (David Haag)
i just remembered another easy way to remove the film from the back glass leaving little or no glue. use a heatgun and begin warming up the window on the top. begin peeling off the film where you have warmed it up . continue warming a little at a time and then peeling it off. you will have to get it pretty hot for this to work. go from one side to the other and be patient. i hope this helped.
[Modified by David Haag, 12:32 AM 4/4/2002]
What you need to do is borrow some non-tinted glass from someone till after the inspection, and then swap the tinted glass back in later. Anyone owe you a big favor? :D
Roll your windows down and pull the fuse. Tell them they're broken. No law says you have to have side windows, only front. They generally can't check the rear because the 2" factory tint is wider than the machines sensor. Anthow, that's how I did it in Louisiana.
Re: How do you remove window tint? I cant pass inspection!! (Nitro Junkie)
And with the window fuse thats funny but I dont think so Im not worried about the tint it was in when i bought the car so no skin off my back!
Texas laws do not prohibit you from tinting the back as dark as you want. The sides however have to be 35% or more. Do they check the back in NC?
When I decided to remove the tint from my '86 I experimented with a few different methods (heat gun/razors/etc.) before I finally tried using straight ammonia on a sponge. This method worked very well, just wiped it on let it sit for awhile and the tint just started lifting off the glass. Some parts on the rear glass were more stubborn than others, but it just required wiping on more ammonia until the tint would loosen up. Obviously you should do this in a well ventilated area.
Re: How do you remove window tint? I cant pass inspection!! (USCZBT)
Your're in the service, can't you keep the registration and inspection from your home state?
fp
fp
Re: How do you remove window tint? I cant pass inspection!! (fiddleplayer)
worse case scenario is you just pay a window tinter to only take the tint off.. most places will charge an extra few bucks to tint your car if you already have tint.. the extra cost is for removing it..
i didnt think there were any laws against your rear window being tinted.. out here in CA, any tint at all on side windows is illegal..
- eddie -
- eddie -
Re: How do you remove window tint? I cant pass inspection!! (Eddie N)
most tintshops would charge between 40 to 100 bucks to remove it from a backglass , we charge 40 to remove film just on the backglass , here is a site that is to window tint like corvette forum is to vettes http://www.tintdude.com/messframe.html
i am a moderator on this site and it has some info for tint removal on the right hand side nav bar says tint removal, check it out, my vette is picture of the week lol.
[Modified by vettlesstintguy, 8:20 PM 4/4/2002]
fp
fp
Ill look into this stuff if I cant find a good inspection station :blueangel:
Im looking at a house tomorrow so hopefully by next week Ill have my 2 car garage and well see what I can do :jester
I appreciate the help guys I do!
AND NC checks all tint unless it is factory tint, I went to the inspection place on base so they are like to only straight shooters I know of a couple of good guys that will do it with no problem :yesnod:
Update,
I found a place where the guy was excited to drive a vette (go figure:lol:) he pulled it around to the back checked the lights and that was it!
Got my sticker for $10 and I was on my way I guess you just have to ask the right people where to take your car!
jp
jp
