93 Air Cond/ Cruise problems
My 93 does not select vents properly.. blows either defrost (most settings) or defrost and floor (heater/bilevel). Also the cruise will not engage. Any ideas? Probaly vacuum lines, but I am having trouble locating them.
Your first move should be to buy a Factory Service Manual. Lots of troubleshooting help in it. C4's (and all contemporary cars) have many complicated systems that can't be serviced unless you have an idea how they work. Your cruise problem could be as simple as the defeat switch on the brake or clutch pedal being out of adjustment.
Cruise-In II Veteran
In the Red Help section at Autozone Help/GM 1983-2008 Two-Way Vacuum Check ValvePart Number:
47150
Features & Benefits
Replace when worn or damaged
Part Number: 47150
Weight: 0.02 lbs
Description: Two-way check valve
47150
Features & Benefits
Part Number: 47150
Weight: 0.02 lbs
