1993 auto trans wouldn't shift from 1st: you'll never guess what was the problem!!
So I've been dealing with a serious transmission problem, it wouldn't shift out of first!! I had tried re-setting the TV cable with the factory procedure 3 times, no dice. As you may know; 1993's have a complex TV cable setting procedure because of the TV cable, throttle cable, AND cruise control linkages all being intermeshed. It involves a torque wrench reading inch-lbs, drill bits, yada yada...
When I set it the last time; I noticed the cruise control actuator had a big hole in the rubber diaphragm/bellows thing (looked like a mouse/rat chewed it).
I decided to replace it; it needed replacing obviously in this condition, plus I was curious that it might be interfering with the TV cable since the cable from the actuator integrates with the TV. Not expensive, ~$100 from Advance with a $30 online discount.
I replaced it in <5 min... the car shifts fine!!
I guess the moral is, when diagnosing a shifting problem on a 1993 Corvette w/700r4k, check the cruise control components.
All of the early GM transmissions used vac. to control the shift.
Modulator valve.
I haven't looked at mine to see if it even has one.
I was in the business back in the mid 70's
The turbo 350 kept us all in business for years.
Modulator valve.
the 4L60/700R4 from 1993 does not use vacuum for anything. The TV cable is a cable that operates a throttle valve which adjusts the pressure to the transmission.
My guess is something else was missing. The cruise control has nothing to do with shifting, even though there is a few cables going into the ASR, they all adjust throttle for ASR and cruise control to modulate speed etc.
But, since I will probably get flamed for this, ask PETEK.
I bet the cruise control cable was misaligned and when you reinstalled the vacuum diaghram you fixed the cable for the cruise, which goes in the ASR module.
