starter relay location??
Old 10-08-2010, 05:12 AM
Ricky 91 vette
Ricky 91 vette's Avatar
Default starter relay location??
hi its a 91 vette auto, i need to know where is the starter enable relay located, and does the 12v goes from ign to relay to p/n sw to starter OR ign to p/n sw to relay to starter??? thanks
Old 10-08-2010, 08:06 AM
vetteoz
vetteoz's Avatar
Old 10-08-2010, 11:49 AM
Ricky 91 vette
thanks, is that the info and gauges thing? and what about the power, is it from ign to p/n sw to relay to starter or ign to relay to p/n sw to starter?
Old 10-08-2010, 05:17 PM
Ricky 91 vette
Some more help here pls
Old 10-08-2010, 08:05 PM
rodj
rodj's Avatar
Pic says
Fig 24 - below LH side of IP ( instrument panel )
Power ( heavy yellow) goes Ign switch - relay - inhibitor switch
Time you bought a FSM ; well worth it for this sort of work
Best $60 you will spend
http://forums.corvetteforum.com/c4-p...ce-manual.html
Old 10-09-2010, 04:53 AM
MaSTeRofDZaSTeR
MaSTeRofDZaSTeR's Avatar
Location: "Drive like Hell, you'll get there faster." Tucson AZ
Yes that's the "info and gauges thing". Its your instrument cluster above the relay. In case the pic isn't clear yours should be just like on my '90. Its under the steering wheel if you unbolt the carpet, pull it back and stick your head under there(if you can fit) you can barely see it next to that a/c clutch relay. The ac clutch relay should be marked as such anyway and the starter enable relay is usually marked "12v", but it should be the one closest to the steering wheel(on the right from your view under the wheel).
Old 10-09-2010, 05:29 AM
Ricky 91 vette
OMG i cant believe it!! i tore my car apart every where trying to find the d... relay, i took off the center like screen which i thought it was the IP to find behind it the chime relay or whatever it name is and to pull it out i took off my double din gps!! just to find out its not the one, and after i saw the pic above i went and took off my real ip this time to find nothing behind it!!! now i know what i have to do tomorrow morning after i put everything back together ( i hope ) thanks everyone
Old 10-09-2010, 05:56 AM
MaSTeRofDZaSTeR
lol. Hindsight's not only 20/20, it can be painful. The relay is a little black square, fits in like a plug and comes out with a tug. Replacements like 6 bucks down at an auto parts store. Had to change that little bastard more than once on mine.
Old 10-09-2010, 02:49 PM
Ricky 91 vette
Thanks for all the help from u and other members in this great forum my car is running again, I found the relay and replaced it, it was not to easy to get there but my nightmare is finally over( for now, u never know what surprises a 20 years old car will be hiding for u! Lol) thanks again everyone
Old 10-09-2010, 03:59 PM
MaSTeRofDZaSTeR
Old 10-23-2010, 08:32 PM
shescorvettecrazy
3rd Gear
shescorvettecrazy's Avatar
Default location of starter relay on 1980
I have a 1980 is it in the same location?
Old 10-23-2010, 08:33 PM
shescorvettecrazy
3rd Gear
is it in the same location on a 1980
Old 10-23-2010, 09:26 PM
rodj
rodj's Avatar
Why don't you ask in the C3 Forum
http://forums.corvetteforum.com/c3-tech-performance-3/
this is C4 Dept
Old 12-19-2012, 05:54 PM
tjmac
tjmac's Avatar
Default starter relay wiring
2 yellow wires ign to relay,then yellow/blk power to ns/clutch switch then solenoid relay grounded by pcm blk/yellow ire
Old 12-19-2012, 07:58 PM
leesvet
leesvet's Avatar
I sure hope he hasn't been waiting for that answer.....
Old 12-19-2012, 08:28 PM
vetteoz
vetteoz's Avatar
10-08-2010
I was thinking the same
Old 12-20-2012, 01:06 PM
Ricky 91 vette
Lol, Come on guys , he was trying to help and I really appreciate it, but yah luckly I didn't have to mess with the starter circle since then ( knock on wood), merrychristmas everyone
Old 05-28-2015, 10:30 PM
94corvettecoupe
1st Gear
94corvettecoupe's Avatar
Default How do you get to the relay
Where and exactly what needs to be removed to access the relay?
To starter relay location??
Quick Reply: starter relay location??
