Fuel Filter replace,what's the oring size ?
Hi guys im planning on replace my fuel filter
What's the Oring size on both sides of the Filter or line ?
Thanks !
Thanks !
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
There isn't any o-rings, the fuel filter for our cars (as well as quite a few early GM f/i cars and trucks), has a female inverted flare on either end. Just be sure to use two wrenches!
well I have a 95 and do have o rings on the end of the fuel lines,there about 3/8 dia.I had to buy a pack with many sizes for about 5 bucks.make sure you getthe dark orange ones not black.
mine was in very bad shape.
everything I have found said you should have o rings
http://corvette.wikia.com/wiki/Build..._O-Ring_Filter
http://www.ehow.com/how_6322008_repl...el-filter.html
They are very small and it's hard to figure out if/how they are useful. I'm guessing it's possible to get a seal if you tighten the "s" out of the fittings. My local parts retailers all said no 0-rings are listed in their books. You have to buy the dark-orange "HELP" packs and pick the size that looks the same.
Hope they sell those packs down under.
Did you get your smoking problem figured out?
Thoroughly chapped
NCM Member '09
Here is the fitting close up...
There isn't anywhere for an o-ring to be that wouldn't cause a leak. A male inverted flare (your fuel lines), seats directly against the female flare, trying to put an o-ring in there would result in the o-ring being completely shredded. I've sold GM fuel injection fuel filters since they arrived on the market, and probably only sell 20 or so a day, and I've never been asked for o-rings in 30 years by any flavor of mechanic or shop...
Sammy,
There are sealing rings. The GM # 22514722. That's a fuel line seal that's used on most GM fuel-injection systems for the inlet seal to fuel rails etc. I don't believe you should have a problem finding them or an "equivalent".
Fel-pro might be 4-90457
I don't believe I'd try "generics"!!
Sammy, also don't buy a Fram gas filter, I had one that the inside came loose and partially blocked the fuel flow causing the engine to buck and miss. That was a lot of fun trying to figure out what was wrong....WW
Thoroughly chapped
NCM Member '09
You can pull your fuel pump fuse and run your car until it runs out of fuel, let it cool all the way down, then-with a rag on hand, depress the schrader valve on your fuel rail to relieve any left-over pressure. After you've installed your new filter, turn your ignition on without starting the car, ensure that you have no leaks, and allow your rails to refill, than start it up, and make sure you still have no leaks.
Not to worry, the pump is cooled by the fuel flowing through it.
The rail and fuel line fittings are Saginaw type with o-ring. They are the same size so if you have extra for the top lines they will work below. Some years had a smaller and larger line. Here is a picture of an adapter showing the o-ring.
Thanks guys , im thinking that some models use O-rings and some not
maybe depends on Year , i would love to be 100% sure which years ...
I don't want to take it off and then not being able to install the filter because i dont have the orings ! for example 87 has 2 different fuel line sizes at the rail.
Why some model owners claim to use orings and other don't ?
Thoroughly chapped
NCM Member '09
I really couldn't say...knowing how the male and female flare-fittings mate leave little room for an o-ring, and the fuel filter is the same for all of our cars. Up until about a year ago, I had four GM vehicles that use the same filter, and they get changed anually, and I've never used an o-ring on any of them, and never had a hint of a leak. Now up on the fuel rail is a different story, but those are not inverted flare fittings either. Think of a brake line-inverted flares there too, see any o-rings?
