Dose a 3 row all aluminum radiator = low operating temps+ larger coolant capacity?
There's a ebay vendor selling 3 row all aluminum radiators for $210 but before i buy it i'd like to know what if any advantage does a 3 row all aluminum radiator have over our OEM plastic tank radiators? can i expect lower operating temps and will the addition of a extra row translate in larger coolant capacity? would you buy this radiator?
heres the eBay auction info.
vendor: Jam-n-motorsports
item name: Champion cooling 3 row 91-96 Corvette all aluminum radiator
item number:160478603182
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I see it coming already
Well, Gm thought so for many years. Why do you think they had single, 2 and 3 row radiators? Bigger engines needed more cooling.
I think the larger radiators allow coolant to be more consistent as it will stay in radiator longer to allow it to cool longer.
Why do they tell you to put the largest oil and tranny cooler possible to fight heating of those fluids. Because the fluid has a better chance to cool down.
I suspect anything is better than stock -- esp if you NEED a new radiator.
Well, here in Phoenix with the 110+ summer heat I needed I new radiator to keep my 383 temperatures in order. I went with a Ron Davis aluminum radiator, which I believe it a 2-row model. And, yes it made quite a difference over the stock radiator.
I was thinking more air. I bought a bigger cmf fan. I still got hot in traffic. Then i pulled the thurmastate,still got hot. I pruchased the three core radiator off ebay.and the two small fans. I put the high valume fan out front to push and the two small fans on the engine side to pull. I had to put the thurmasate back in to warm up to 180. I have a 86.
That's how I fixed the problem. $255.00 for rad. 45 on ebay for high volume fan.
Received 3,043 Likes
St. Jude Donor '05
Stock fans are what 12-1300 cfm ea I think (not sure)
There are aftermarkets that pull plenty more air and less amps out there if you hunt around. Buy a good one
According to DeWitt's website, 1700cfm is stock. I would assume that's the main fan. The aux model probably is the same. Otherwise, it would seem like they'd "fight" each other.
Im running the stock (LT1) 180 dg thermostat. I had to replace rad. so I installed a dewitts-great radiator but almost the same temps-it cools down faster-I would imagine if I used a 160 stat and reprogram the fans it would be alot cooler-but im leaving it with the stock stat and fan settings.
I did have a Mazda MX6 that needed a rad. I installed a larger one and the car ran much cooler without changing settings and stat.
St. Jude Donor '05
I had referred to but not clarified my post by meaning the 90 up. I cannot recall the source but Im almost positive the aux fan on the 89- is about 800, not much. Main fan have no idea.
I wouldn't mind knowing what the '89s push from the factory!!!
Ok. here we go have 96 LT-4 live in Houston 100 everyday old Rad. stock 14 years old gave up 180 stat motor mostely stock some bolt ons. Just ordered a Dewitts Alum. 2 row but very wide so biger a*s raditor for the thing and haveing the Ecm turn on the fans at 195 put a 2" wide peace under the air intake draw in more air ? The Rad..$ 495.00 not cheep but will send it now not in 4-to 6 weeks . So new Rad. coolent my time little ods and ins about $650.00 will have it in in about two weeks ..Will see if $650.00 you can a cooler 96 Corvette in 110 heat.. Will let you know... Was running at red light up tp 235 240 and highter sometimes, had to turn off air start moveing and it would cool off ..The old Rad. had been boiled out ... Will see?????
Cancell that over priced coke can....!
I'm in Houston as well. Bought this rad, set it next to a DeWitt and they are IDENTICAL in every detail.
http://stores.ebay.com/Engineered-Cooling-Products
My temps were doing the same thing...235+ with a/c in summer afternoon traffic. Now, today I cruised at 190 with a/c in 97* ambient...it climbs to 210 maybe in traffic.
The only real mod is to the rubber mounting blocks. The new rad is fatter and fills the shroud more. Blocks have to be trimmed with a razor. Fit is exact. Fill with dexcool, add water wetter and relax.
BTW...it'll come UPS in 2 days.
$210........double row, full 1" each. Its FAT and it works. Been in my car for a yr.
Thanks ,I was on the phone and the internet for 3 hrs and found cheeper ones but all 4-to6 weeks out so the dewitt dude said : I'll send you one today .. So what to do? It's comeing and I hope the thing is cooled off for good turn off air on air was pain.. It's a wife thing I'll hot beep beep... I'm a hot rodder just go faster . Haveing the air on in and old vett is kinda nice...
