optimum timing
Old 04-01-2002, 06:20 PM
mk842766
mk842766's Avatar
Default optimum timing
I've set my timing to 8 deg.......but it seems to rum better at 10....do I have something out of whack, or is it ok to run at 10....
Old 04-01-2002, 06:29 PM
scorp508
scorp508's Avatar
One night I played with my timing while at the track. I started at 6, went to 8 and gained 1mph, went to 9.5 and gained another 0.5 mph for a total of 1.5 mph. I hvae seen others go as high as 12 w/o pinging.
Old 04-01-2002, 06:33 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Default Re: (scorp508)
Scorp is right; it depends on what your motor likes. You realy need a scan tool (or time slips) since the ECM may be pulling timing before you can hear ping. I have never heard ping with the Vette but the scanner showed knock counts.
I just pulled 2deg, back to +6deg due to knock counts and spark retard at WOT. I may have to pull another deg or two to remove a copla remaining knock counts. But I'm now running a HyperTech Stage II chip which may be giving me a little more advance at WOT.
Old 04-01-2002, 07:09 PM
CFI-EFI
CFI-EFI's Avatar
Default Re: optimum timing (mk842766)
Mine is set at 14* btdc, running on 85 octane gasoline. It seems to like it.
Old 04-01-2002, 09:42 PM
mk842766
mk842766's Avatar
Thanx guys...I'll reset and see how she goes....
Old 04-02-2002, 10:49 AM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
For optimum timing you need to burn your own chips. But yes, you could see some improvements. With more efficient heads you will not need to run as much timing. Currently under WOT I have my spark advance set to no higher than 29.2*. With the stock chip I would bet you are somewere around 38*-40*. I can't imagine you need more timing than that, but every engine is different.
[Modified by ski_dwn_it, 9:50 AM 4/2/2002]
To optimum timing
Quick Reply: optimum timing
