Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-14-2010, 10:58 AM   #1
KCSS
CF Member
Default 1992 Cooling Fans & AC Compressor not working...correlation?
I'm calling on the wisdom of the forum. I have a 92' LT1 I purchased the car in the early spring and never noticed it running hot, probably because it was much cooler outside. I don't drive the car that often but have noticed in the summer months it's getting really hot. Coolant temps of 250+!! I took it home and have no cooling fans. When I bought the car I was told that the AC needed a charge but upon further investigation the compressor isn't even trying to kick on. Could these two be related?
I looked at the passenger side door fuse box, but didn't see any fuses for the cooling fans? I'm assuming they are under the hood? Could I be lucky enough that these two are related and just a fuse or relay problem?
I appreciate any help.
Thanks!
KCSS is offline   Reply With Quote
Old 09-14-2010, 11:35 AM   #2
twin540
CF Senior Member
twin540's Avatar
Check the fuse links behind the battery. I had same problem couple months ago.
twin540 is offline   Reply With Quote
Old 09-14-2010, 11:39 AM   #3
onedef92
CF Senior Member
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
onedef92's Avatar
The cooling fan relays themselves are on the same side as the A/C compressor. Trying to locate a pic of the engine bay for clarity.
onedef92 is offline   Reply With Quote
Old 09-15-2010, 12:38 PM   #4
KCSS
CF Member
Is there anyway to identify if it is a fuse link or relay without just replacing them to see?
Old 09-15-2010, 03:21 PM   #5
twin540
CF Senior Member
twin540's Avatar
When fuse links go bad you can visually see them burnt. Check and follow the voltage to the relay.
Reload this Page 1992 Cooling Fans & AC Compressor not working...correlation?
Tags
1992, 92, ac, acnot, c4, coming, compressor, condenser, coolant, cooling, corvette, fan, refrigerator, stopped, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
