Flow numbers of TPI bases
Does anyone know where I can find flow numbers for the different TPI bases and also for different runners?
JMR
JMR
Re: Flow numbers of TPI bases (CrazyBlk86)
Runners (measured individually)
Stock....................203.17 cfm
ACCEL................242.02 cfm
Extrude/ACCEL...275.83 cfm
Super Ram............289.18 cfm
Intake manifold with 3/8 inch radiused intlet
.............................222.45 cfm
Stock intake manifold with runner
Stock....................198.72 cfm
ACCEL................213.52 cfm
Extrude/ACCEL....217.11 cfm
Super Ram............220.67 cfm
ACCEL Hi-Flow intake manifold with 3/8 inch
radiused inlet.........251.51 cfm
ACCEL Hi-Flow intake manifold with runner
Stock....................215.83 cfm
ACCEL................232.53 cfm
Extrude/ACCEL....243.21 cfm
Super Ram............240.24 cfm
Extrude-Honed ACCEL Hi-Flow intake
manifold with 3/8 inch radiused inlet
............................275.83 cfm
manifold with ACCEL runner
............................266.94 cfm
Edelbrock Performer RPM manifold
(Stock)..................286.51 cfm
Edelbrock Victor Jr.
.............................275.24 cfm
My guess is that the Scoggin Dickey Vortec TPI base will flow the same as a edelbrock once it has been de-burred (alot)
Re: Flow numbers of TPI bases (ZD1)
Flow numbers are always great, but they can be very miss leading. If the engine had a continous flow through the runners and manifold it could tell you alot, but it does not. What happens to the air flow when the intake valve closes?
