85 corvete timing
Old 07-15-2018, 04:15 PM
TLA
3rd Gear
TLA's Avatar
Default 85 corvete timing
What is the degree's on a 1985 Corvette my lable is damaged?
Old 07-15-2018, 09:36 PM
playsdixie
playsdixie's Avatar
pretty sure it's 6, I run my 85 at 8
Old 07-16-2018, 01:25 AM
gerardvg
gerardvg's Avatar
6 degrees remember to disconnect the set timing ESC wire to stop ecm changing advance while setting it.
One more thing, the balancer outer ring is known to slip.
Usually a good idea to check no1 piston is at tdc when timing mark is at tdc, if the outer balancer ring slips it usually goes backward to timing cover.
Old 07-16-2018, 11:24 AM
vader86
vader86's Avatar
Received 1,398 Likes on 1,015 Posts
6 is the base timing setting, but I'd run 8. I always ran 8 on my 86. Always on 87 octane as well. Never got knock.
Old 07-18-2018, 02:19 PM
ctmccloskey
Support Corvetteforum!
ctmccloskey's Avatar
Received 1,102 Likes on 874 Posts
If you do follow the advice of some and run 8 degrees instead of 6 then be sure that your knock sensor/s are working properly.
By going up on the timing you MIGHT loose the ability to run 87 octane fuels. More timing would make the car want more octane, if that is not a problem then go for it.
If your knock sensors are out of wack you might hurt the engine with the detonation that can occur.
I have a 1968 BB C3 for going fast, my 1988 is a cruising car and I am satisfied getting 30 mpg driving it easily. I also use 87 octane and have no pinging or knocking at all.
I test my knock sensors every year or two. I bought a kit from Mid-America which had like 8 different testing rigs that plug and play. No modifying or splicing just put the tester in between the sensor and the harness and see in real time what it is sending the engine. It was the best $100 I spent on my C4. I have helped others set up their engine quickly with these tools. You can tap a ratchet on the block and you see the response from the knock sensor.
Good luck with your Corvette!
To 85 corvete timing
Quick Reply: 85 corvete timing
