Need helping with my smog plumbing.
1990 coupe that I am trying to put back together. My problem is the diverter valve. There is the bottom hole which has a metal tube that goes across to the air pump, then there is the top hole which goes to a muffler. The two ports that face the windshield are my problem. Which side goes to the cat and which one to the exhaust manifolds?
It's the only thing holding me up from trying to start this thing for the first time in two years.
standing in front of the car looking toward the rear. the tube on the right goes into a T and into the exhaust manifold. The hose on the left goes to a steel line then under the car. (I assume to the cat converter). hope this helps any other questions let me know. Rich
