Corvette Enthusiast Magazine EFI Manifold Test
Corvette Enthusiast Magazine (October 2010) did a nice manifold comparison on a 350 Chevy this month.
First, Im NOT going to post the whole article here, because its a fairly good Corvette Magazine and we should go out and buy copies to support them (or Im sure they will post it on the web in time).
But I did put the results in graph form so its easier to compare (they only listed them in print form), and will post them up here.
Test Engine Specifications:
355 Chevy
6.0 inch rod
GM Vortec Heads Ported 278 CFM Intake 210 CFM Exhaust
2.02/1.60 valves
10.95:1 Compression
Dyno headers
1:6 ratio Intake & 1:5 ratio Exhaust roller rockers
Cam One: 210/220 Duration @ .050 - 0.332/0.342 Lobe Lift 114 Lobe Centerline
Cam Two: 226/234 Duration @ .050 0.353/0.355 Lobe Lift 112 Lobe Centerline
Manifolds Tested:
TPI = Accel large tube runners - Scoggin Dickey Vortec TPI base 58mm Tb
Holley single plane EFI manifold 750 CFM Tb
GM RamJet EFI manifold 75 mm single Tb
Holley Stealth Ram EFI manifold 58 mm Tb
Interesting?
355 Chevy
6.0 inch rod
2.02/1.60 valves
10.95:1 Compression
Dyno headers
Manifolds Tested:
Interesting?
Odd that the TPiS MiniRam wasn't tested with this batch. I guess maybe it's been tested to death...? Still, it would have been really nice to see how it stacked up to the ones tested in the article.
Corvette Enthusiast Magazine (October 2010) did a nice manifold comparison on a 350 Chevy this month.... I put the results in graph form so it’s easier to compare (they only listed them in print form), and will post them up here.
Cam One: 210/220 Duration @ .050 - .531"/.513" Lobe Lift – 114 ICL
Cam Two: 226/234 Duration @ .050 – .565"/533" Lobe Lift – 112 ICL
Interesting?
Interesting?
It should be noted how well the ported Vortecs did in this test. I would predict/estimate results from other favorite aftermarket heads not much better than this. (wink, wink, nudge, nudge, know what I mean?!)
I also posted the actual lift numbers with the rocker ratios applied. That way no one else has to do the math.
Thanks again SuperL98 for posting this data. Is the part of the C4 strip-down I recently saw...Or is this an independant comparison?
Left this out.
From the article:
The Holley single plane has 8 inch end runners, and 7.5 inch center runners.
The GM RamJet runners are 5.75 long.
The Holley Stealth Ram has 7 inch runners.
So (according to the article) the Holley single plane has longer runners than the other two (not counting the TPI setup), which might explain the better torque with the smaller Cam1.
From the article:
I was a hair surprised and the midrange results of the single plane vs the HSR.
A single 75mm TB (LSx style) will flow about as good as a 52mm twin setup (TPI style) which is about 760 cfm. 75mm has abit more flow, around 780cfm.
On the bigger cams, the HSR will have the advantage with its 58mm TB. Wont choke it as bad.
But this is an interesting article in that they used near 11 to 1 compression on IRON heads with that small cam (either one is too small for that compression and pump gas). I really dont think this motor would run too happy on pump gas, you'd have to be very very careful on the tune/timing this motor would see.
YOu can see how the heads are choking this setup or they are having some valve float. That bigger cam doesnt pull any higher rpm than the smaller one, and it should peak alittle higher than 5800 rpm
You guys will never learn. These sell out rag "test" are nothing more than shams to drum up sales/business for what ever product the supporting vendor for the test wants to sell.
In this case it appears Holley needs to sell some HSR's.
Will
Will
Just like anything where advertising keeps your doors open - it's pretty tough to be on the up and up.
I always take dyno "shootouts" from mags with a grain of salt. And It's pretty obvious who is behind the test numbers most of the time. It happens like crazy in the import mags.
